    Fix Windows 10 Update Issues
HP ENVY 27s 27-inch Display Product Specifications
Z6W67AA
Display size
27"
Display type
IPS
Panel active area(inches)
23.49 x 13.21 in
Panel active area(cms)
59.67 x 33.56 cm
Brightness
350 cd/m²
Pixel Pitch
0.1554 mm
Inputs
1 HDMI 1.4; 1 HDMI 2.0; 1 DisplayPort™ 1.2
Viewing angle
178° horizontal; 178° vertical
Scan range (horizontal)
Up to 134 kHz
Scan range (vertical)
Up to 60 Hz
Recommended resolution
3840 x 2160 (4K UHD)
Aspect ratio
16:9
Static contrast ratio;Dynamic contrast ratio
1300:1 static; 10000000:1 dynamic
Response time
5 ms gray to gray
Power consumption
100-240 VAC at 50 - 60 Hz
Tilt
Tilt: -5 to +25°
Power supply
65W maximum, 45W typical; Standby mode: 0.5W
Dimensions
61.35 x 15.5 x 42.92 cm (with stand); 61.35 x 4 x 36.26 cm (without stand)
5.51 kg (with stand); 4.85 kg (without stand)
