Advisory: HP mt20 Mobile Thin Client - Citrix Receiver Version 4.7.0A-1 Is Only Showing on Half of the Laptop Screen When Using Dual Monitor Configuration
Release date : 11-Apr-2018
Last updated : 11-Apr-2018
DESCRIPTION
The Citrix Receiver window only fills half of the mt20 internal display.
This occurs when logging on to the server when using a dual monitor (one external monitor) setup.
This occurs when an external monitor is connected.
SCOPE
Configuration:
Citrix Receiver version 4.7.0A-1
External monitor is connected
Systems:
HP mt20 Mobile Thin Client (ENERGY STAR)
HP mt20 Mobile Thin Client series
Operating Systems:
Microsoft Windows 10 IoT (Build 1507)
RESOLUTION
Resolve the issue as follows:
Open
Settings,
System, and then
Display.
Under
Scale and layout set the scaling to
100%.
Hardware platforms affected : HP mt20 Mobile Thin Client, HP mt20 Mobile Thin Client, HP mt20 Mobile Thin Client (ENERGY STAR)
Support Communication Cross Reference ID : IA05971459
Some features of the tool may not be available at this time. We apologize for this inconvenience and are addressing the issue.Minimize Chat bot windowLoading ChatbotNew Message
