HP LaserJet MFP M72625, M72630 - Removal: Toner collection unit
This document provides the procedures to remove the toner collection unit.
Click the following link to view a video that demonstrates how to remove the toner collection unit:
Reverse the removal steps to install the assembly.
Before performing service
  • Disconnect the power cable.
      warning:
Use the table below to identify the correct part number for your printer. To order the part, go to www.hp.com/buy/parts
Toner collection unit part number
X3A60-67901
Required tools
  • No special tools are needed to remove or install this assembly.
After performing service
Turn the printer power on
  • Connect the power cable.
Post service test
When the power is turned on, listen for normal startup sounds.
Check the control-panel display for error messages.
Make sure that the printer initializes to a Ready state.
Copy, scan, or print a document. Verify the document copies, scans, or prints correctly.
Remove the toner collection unit
  1. Release two tabs (callout 1), and then pull the toner collection unit away from the printer to remove it (callout 2).
    Figure : Remove the toner collection unit
