HP PCs - Send Files to Nearby Bluetooth Devices Using Nearby Sharing (Windows 10)
This document applies to HP computers with Windows 10.
The Nearby Sharing feature in Windows 10 lets you send files over Bluetooth to nearby Windows 10 PCs. This works in any app with the Share function, such as Photos or File Explorer. You can also share web pages in Microsoft Edge.
The devices you want to share with must have Bluetooth turned on and be in Bluetooth range. In addition, they must be running the Windows 10 April 2018 Update (or later) and have Nearby Sharing enabled.
Video overview
Use the following steps to enable Nearby Sharing, and then share your files wirelessly.
  1. To enable Nearby Sharing, click the Action Center icon in the lower-right, and then click the Nearby Sharing button. Do this on all devices that will use Nearby Sharing.
    Enabling Nearby Sharing in the Action Center
  2. In File Explorer, select the file you want to share. On the Share tab, click Share.
    This example demonstrates how to use Nearby Sharing in File Explorer, but the steps are similar in all apps with sharing capability.
    Selecting the file to share in File Explorer
  3. The Share window opens. Select the PC with which you want to share.
    Selecting the computer to share with
  4. A message displays indicating that the file is waiting to be shared.
    Sharing message on sending PC
    On the receiving device, a message displays indicating that a file is being shared.
    Sharing message on the receiving PC
  5. Choose Save, or Save & Open.
    If you select Save, a message displays showing the transfer progress and then shows where the received file was saved.
    If you select Save & Open, a message displays showing the progress. When the transfer is complete, a message displays asking how you want to open the file.
    Sharing progress message on receiving PC
    Selecting an app to open the file
  6. The file opens on the receiving device in the selected app.
    File on the receiving PC
  7. To share a link to a web page in Microsoft Edge, click the Share button in the upper-right corner of Edge. When the Share window opens, select the device with which you want to share.
    When the receiving device accepts the shared link, Microsoft Edge opens to that web page.
    Sharing a link to a web page
