    Fix Windows 10 Update Issues
    Are you working from home?
HP 13.3-inch Privacy Screen Filter Specifications
Product image
Figure : HP 13.3-inch Privacy Screen Filter
Specification
Features
Diminishes screen readability for anyone not seated directly in front of the notebook.
Retains use of camera, sensors, and interactive touchscreen and pen input.
Resists scratches and fingerprints.
Anti-glare and exact-fit
Apply and remove the filter with reusable adhesive corner tabs.
Compatible notebook screen size (diagonal)
HP x2 1012 G2 Tablet
HP ProBook 430 G4 and G5 Notebook PC
HP EliteBook x360
HP EliteBook 1040 G4 Notebook PC
Viewing angle
60°
Transmission
68%
Thickness
0.29 mm (0.01 in)
