    Are you working from home?
    Fix Windows 10 Update Issues
HP 15.6-inch Privacy Screen Filter Specifications
Product image
Figure : HP 15.6-inch Privacy Screen Filter
Specification
Features
Diminishes screen readability for anyone not seated directly in front of the notebook.
Retains use of camera, sensors, and interactive touchscreen and pen input.
Resists scratches and fingerprints.
Anti-glare and exact-fit
Apply and remove the filter with reusable adhesive tape.
Compatible notebook screen size (diagonal)
HP ProBook 450 G4 Notebook PC
HP ProBook 655 G2 Notebook PC
HP ZBook 15 G4 Mobile Workstation
Viewing angle
60°
Transmission
68%
Thickness
0.29 mm (0.01 in)
