    Fix Windows 10 Update Issues
    Are you working from home?
HP mt44 Mobile Thin Client Specifications
Product image
Figure : HP mt44 Mobile Thin Client
Operating systems
Specification
Preinstalled
Microsoft Windows 10 IoT Enterprise for Thin Client
In accordance with Microsoft support policy, HP does not support the Windows 8 or Windows 7 operating system on products configured with Intel and AMD 7th generation and later processors or provide any Windows 8 or Windows.
Not all features are available in all editions or versions of Windows. Systems might require upgraded and/or separately purchased hardware, drivers, software or BIOS update to take full advantage of Windows functionality. ISP fees might apply and additional requirements might apply over time for updates.
Processors
Specification
AMD Ryzen 3 2300U with Radeon Vega Graphics
2.0 GHz base frequency, up to 3.4 GHz burst frequency
4 cores
6 MB cache
Integrated with processor
Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. Performance and clock frequency vary depending on application workload and hardware and software configurations. AMD numbering is not a measurement of higher performance.
Processor speed denotes maximum performance mode; processors will run at lower speeds in battery optimization mode.
Graphics
Specification
Integrated
AMD Radeon Vega Graphics
Displays
Specification
Displays (optional)
Non-Touch
35.6 cm (14 in) diagonal FHD IPS anti-glare LED-backlit, 220 cd/m², 45% sRGB (1920 x 1080)
35.6 cm (14 in) diagonal FHD IPS anti-glare LED-backlit, 220 cd/m², 45% sRGB with HD camera (1920 x 1080)
35.6 cm (14 in) diagonal FHD IPS anti-glare LED-backlit, 220 cd/m², 45% sRGB with HD IR webcam (1920 x 1080)
35.6 cm (14 in) diagonal FHD IPS anti-glare LED-backlit, 220 cd/m², 45% sRGB for WWAN (1920 x 1080)
35.6 cm (14 in) diagonal FHD IPS anti-glare LED-backlit, 220 cd/m², 45% sRGB with HD camera for WWAN (1920 x 1080)
35.6 cm (14 in) diagonal FHD IPS anti-glare LED-backlit, 220 cd/m², 45% sRGB with HD IR webcam for WWAN (1920 x 1080)
HP Sure View Integrated Privacy Screen 35.6 cm (14 in) diagonal FHD IPS anti-glare LED-backlit, 700 cd/m², 72% sRGB with HD IR webcam for WWAN (1920 x 1080)
Must be configured at purchase.
Touch
35.6 cm (14 in) diagonal FHD IPS LED-backlit touch screen with Corning Gorilla Glass 3, 220 cd/m², 45% sRGB with HD IR webcam for WWAN (1920 x 1080)
HD content required to view HD images.
Supported displays (maximum resolution)
HDMI
Upto 4K at 60 Hz
Four independent displays when on HP UltraSlim Docking Station
2K at 60 Hz via DisplayPort 1
2K at 60 Hz via DisplayPort 2
1920 x 1200 at 60 Hz via VGA
Four independent displays when on HP Elite USB-C Dock G4
1920 x 1200 at 60 Hz via HDMI
Resolutions are dependent upon monitor capability and resolution and color depth settings.
Storage/drives
Specification
Primary storage
128 GB M.2 2280 SATA-3 flash memory storage drive
For storage drives, GB = 1 billion bytes, TB = 1 trillion bytes. Actual formatted capacity is less.
Memory
Specification
Standard
DDR4 - 2400 (transfer rates up to 2400 MT/s)
(2) SODIMM slots supporting dual-channel memory (both slots are customer accessible/upgradable)
Configurations
8 GB Total System Memory (4 GB x 2)
Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory slots.
Maximum
8 GB
Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility. If memory speeds are mixed, the system might perform at the lower memory speed.
Audio/multimedia
Specification
Audio
Bang & Olufsen
(3) integrated multi-array microphones
(2) integrated stereo speakers
720p HD webcam
Includes HD IR webcam
High-definition (HD) content required to view HD images.
Sold separately or as an optional feature.
Keyboards/pointing devices/function keys
Specification
HP Premium keyboard
HP Premium Collaboration Keyboard with dual-point
Spill-resistant with drain (thin layer of Mylar film under the keyboard)
Backlit with HP Dura Keys (optional)
Includes privacy feature
Pointing devices
Clickpad with multi-touch gestures support
Taps enabled as default
Function keys
Function keys
F1 – Display switching
F2 – Blank or privacy
F3 – Brightness down
F4 – Brightness up
F5 – Audio mute
F6 – Volume down
F7 – Volume up
F8 – Microphone mute
F9 – Blank or Keyboard backlit toggle
F10 – Number lock
F11 – Wireless
F12 – Calendar
Additional keys
Share/Present
Call Answer
Call End
Hidden function keys
Fn+R – Break
Fn+S – Sys Rq
Fn+C – Scroll Lock
Ports/slots
Specification
USB ports
(1) USB 3.1 Gen 1
(1) USB Type-C (Alt Mode)
(1) USB 3.1 Gen 1 (Charging)
(1) HDMI 2.0
HDMI cable sold separately.
Other
(1) RJ-45 Gigabit Ethernet interface
(1) docking connector
(1) Headphone/microphone combo
Slots
Smart Card reader (optional)
(1) External Micro SIM Slot (3FF)
Networking/communication
Specification
Broadband Wireless (WWAN)
HP lt4132 LTE/HSPA+ 4G Mobile Broadband
WWAN module is optional, must be configured at the factory, and requires separately purchased service contract. Check with service provider for coverage and availability in your area. Connection speeds vary due to location, environment, network conditions, and other factors. 4G LTE not available on all products, in all regions.
Wi-Fi (WLAN)
Intel Dual Band Wireless-AC 8265 802.11a/b/g/n/ac (2x2) Wi-Fi and Bluetooth 4.2 Combo, non-vPro 3
Wireless access point and Internet service required and sold separately. Availability of public wireless access points limited. The specifications for the 802.11ac WLAN are draft specifications and are not final. If the final specifications differ from the draft specifications, it might affect the ability of the notebook to communicate with other 802.11ac WLAN devices. Wireless features, performance and support may vary depending on environmental variables such as placement, settings and firmware of the access point. Contact your wireless vendor for support.
Wired LAN
Realtek PCIe GbE Family Controller 10/100/1000
The term "10/100/1000" or "Gigabit" Ethernet indicates compatibility with IEEE standard 802.3ab for Gigabit Ethernet, and does not connote actual operating speed of 1 Gb/s. For high-speed transmission, connection to a Gigabit Ethernet server and network infrastructure is required.
NFC
NXP NPC300 Near Field Communications (NFC)
Miracast
Support for Miracast
Supported protocols
Microsoft RDP
VMware Horizon RDP/PCoIP
VMware Blast
Citrix ICA/HDX
Protocols are dependent on operating system installed.
Software/security
Specification
Application
BIOS
HP BIOSphere Gen4 (requires AMD 8th generation processors)
Master Boot Record Security
HP Power On Authentication
Secure Erase (methods outlined in the National Institute of Standards and Technology Special Publication 800-88)
Pre-boot Authentication
Communication/connectivity
HP Native Miracast support
NFC Antenna
HP Value add software
HP Noise Cancellation software
HP Velocity
HP EasyShell
Manageability
HP Device Manager
HP ThinUpdate
HP BIOS Config Utility (BCU) (available for download)
Security
Integrated smart card reader
HP FingerPrint Sensor
IR camera for facial recognition
Trusted Platform Module (TPM) 2.0
Security lock slot
Client security software (optional)
HP Write Manager
HP SureStart Gen4
HP Secure Erase
HP USB Port Manager
Microsoft Windows Defender
Internet connection required for updates.
Software performance and support might vary depending on customer environment and backend.
Power
Specification
Power supply (external)
65 W Smart AC adapter
45 W Smart AC adapter
45 W 2-prong AC adapter (Japan only)
65 W EM Smart AC adapter
45 W USB Type-C adapter
65 W USB Type-C adapter
Availability might vary by country/region.
Primary battery
HP 3-cell Long Life Li-Ion (50 WHr)
Supports HP Fast Charging
Battery is internal and not replaceable by customer.
Battery life
Up to 12 hours
Windows 10 MM14 battery life varies depending on various factors including product model, configuration, loaded applications, features, use, wireless functionality, and power management settings. The maximum capacity of the battery naturally decreases with time and usage.
Power cord
2-wire plug – 1.0 m (3.28 ft) (Japan only)
3-wire plug – 1.0 m (3.28 ft)
3-wire plug – 1.8 m (5.91 ft)
Duckhead power cord – 1.0 m (3.28 ft)
Duckhead power cord – 1.8 m (5.91 ft)
Physical specifications
Specification
Dimensions (W x D x H)
326.14 x 234.19 x 18.03 mm (12.84 x 9.22 x 0.71 in)
Touch
Starting at 1.61 kg (3.35 lb)
Non-touch
Starting at 1.53 kg (3.37 lb)
Weight varies by configuration and components.
