    Windows 11 Upgrade Guide
HP Pavilion x360 - 14-ba143tx Product Specifications
3FS64PA
Intel® Core™ i5-8250U (1.6 GHz base frequency, up to 3.4 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
Flash cache
8 GB
4 GB DDR4-2400 SDRAM (1 x 4 GB)
Video graphics
NVIDIA® GeForce® MX130 (2 GB DDR3 dedicated)
1 TB 5400 rpm SATA SSHD
14" diagonal HD SVA WLED-backlit multitouch-enabled edge-to-edge glass (1366 x 768)
Keyboard
Full-size island-style keyboard
Pointing device
Intel® 802.11a/b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 Combo
1 HDMI 1.4; 1 headphone/microphone combo; 1 USB 3.1 Type-C™ Gen 1 (Data Transfer up to 5 Gb/s); 2 USB 3.1 Gen 1 (Data transfer only)
Dimensions (W x D x H)
33.48 x 22.69 x 2.07 cm
Starting at 1.63 kg
65 W AC power adapter
3-cell, 41 Wh Li-ion prismatic
HP 3D DriveGuard; HP Audio Switch; HP Documentation; HP ePrint; HP JumpStart; HP Recovery Manager; HP Support Assistant; HP Sure Connect
