Document ID: c05932231
Version: 1
Advisory: HP Remote Graphic Software (RGS) - Inconsistent Remote Audio results from SLED Sender
Release date : 14-Feb-2018
Last updated : 15-Feb-2018
DESCRIPTION
After installing the RGS Sender, intermittent issue where audio controls may not be visible, and receiver does not reliably get an audio signal.
SCOPE
Systems:
  • HP Remote Graphics Software (RGS)
Operating Systems:
  • SUSE Linux Enterprise Desktop 11
  • Suse Linux Enterprise Desktop 12
RESOLUTION
To fix this issue:
  1. Revert /etc/pulse/default.pa to the original.
  2. Add the command "/usr/bin/pulseaudio--kill" in the /usr/bin/start-pulseaudio-x11 script just before the command to start pulseaudio.
Hardware platforms affected : HP Remote Graphics Software (RGS), HP Remote Graphics Software (RGS)
Support Communication Cross Reference ID : IA05932231
