OMEN by HP - 15-ce523tx Product Specifications
3PU41PA
Intel® Core™ i7-7700HQ (2.8 GHz base frequency, up to 3.8 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
Intel® HM175
Video graphics
NVIDIA® GeForce® GTX 1050 (4 GB GDDR5 dedicated)
1 TB 7200 rpm SATA
15.6" diagonal FHD IPS anti-glare WLED-backlit (1920 x 1080)
Keyboard
Pointing device
Intel® 802.11a/b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo
1 HDMI; 1 headphone/microphone combo; 1 microphone-in; 1 Mini DisplayPort™; 1 RJ-45; 1 USB 3.1 Type-C™ Gen 1 (Data Transfer up to 5 Gb/s, DP1.2, HP Sleep and Charge); 3 USB 3.1 Gen 1 (1 HP Sleep and Charge)
Dimensions (W x D x H)
38.85 x 27.55 x 2.48 cm
Starting at 2.57 kg
150 W AC power adapter
4-cell, 70 Wh Li-ion polymer
Bang & Olufsen, dual speakers, HP Audio Boost
HP 3D DriveGuard; HP Audio Switch; HP Documentation; HP ePrint; HP JumpStart; HP Orbit; HP Recovery Manager; HP Support Assistant; HP Sure Connect; OMEN Command Center
