HP 285 G3 Microtower Business PC Specifications
Product image
Figure : HP 285 G3 Microtower Business PC
Operating systems
Specification
Preinstalled Windows
Windows 10 Pro 64
Windows 10 Pro 64 (National Academic only)
Windows 10 Home 64 (National Academic only)
Not all features are available in all editions or versions of Windows. Systems might require upgraded and/or separately purchased hardware, drivers, software or BIOS update to take full advantage of Windows functionality. Windows 10 is automatically updated, which is always enabled. ISP fees might apply and additional requirements might apply over time for updates.
Preinstalled (other)
FreeDOS 1.2
Processors
Specification
7th Gen AMD PRO A6-9500 APU
3.5 GHz base frequency, up to 3.8 GHz burst frequency
2 cores
65 W
7th Gen AMD PRO A8-9600 APU
3.1 GHz base frequency, up to 3.4 GHz burst frequency
4 cores
65 W
7th Gen AMD PRO A10-9700 APU
4 cores
65 W
AMD Ryzen 3 PRO 1300
3.5 GHz base frequency, up to 3.7 GHz burst frequency
4 cores
65 W
AMD Ryzen 3 PRO 1200
4 cores
65 W
AMD Ryzen 5 PRO 1500
4 cores
65 W
AMD B350
Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. Performance and clock frequency vary depending on application workload and hardware and software configurations. AMD numbering is not a measurement of higher performance.
Graphics
Specification
Integrated
AMD Radeon R5 series (integrated on A6 processor)
AMD Radeon R7 series (integrated on A8/A10 processor)
Discrete
AMD Radeon R5 420
AMD Radeon R7 430
NVIDIA GeForce GT 730
High-definition (HD) content is required to view high definition images.
Memory
Specification
Type
DDR4 2666 (transfer rates up to 2666 MT/s)
Runs at 2400 MT/s when configured with A-series APU.
Maximum
32 GB
Number of slots
(2) DIMM
Configurations
4 GB DDR4-2666 UDIMM NECC (4 GB x 1)
8 GB DDR4-2666 UDIMM NECC (8 GB x 1)
8 GB DDR4-2666 (4 GB x 2)
16 GB DDR4-2666 UDIMM NECC (16 GB x 1)
16 GB DDR4-2666 UDIMM NECC (8 GB x 2)
Storage
Specification
SATA 3 (8.89 cm (3.5 in) or 6.35 cm (2.5 in))
500 GB 7200 RPM SATA Hard Disk Drive
1 TB 7200 RPM SATA Hard Disk Drive
2 TB 7200 RPM SATA Hard Disk Drive
Solid state drives
256 GB TLC SSD 2.5 in
128 GB TLC SSD 2.5 in
128GB M.2 NVMe (Value) SSD
256GB M.2 NVMe (Value) SSD
SD card reader
SD/SDHC/SDXC SD card reader (card sold separately)
Optical Disk Drive (optional or add on feature)
DVD-ROM 9.5 mm
DVD-Writer 9.5 mm
For solid state drives or hard drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 36 GB (for Windows 10) is reserved for system recovery software.
Audio
Specification
Type
Realtek ALC3601
Microphone/headphone combo jack
Yes
Standard internal speaker
Yes (2 Watts)
Keyboards and pointing devices
Specification
Keyboards (optional or add-on feature)
HP PS/2 Slim Business Keyboard (standalone)
HP USB Business Slim Antimicrobial Keyboard (standalone for China only)
HP USB Slim Business Keyboard
HP USB Keyboard
USB Business Slim Standalone Wired Keyboard
Mice (optional or add-on feature)
HP PS/2 Mouse
HP USB Antimicrobial Mouse (China only)
HP USB Optical Mouse
HP USB Hardened Mouse
HP Universal USB Wired Mouse
Ports/slots/bays
Specification
Front in/out
(2) USB 3.1 Gen 1
(1) Microphone/headphone combo jack
(1) SD card reader
Rear in/out
(4) USB 3.1 Gen 1
(2) USB 2.0 ports
(1) Ethernet/RJ45 port
(1) Audio line out
(1) Audio line in
(1) VGA
(1) HDMI
Internal in/out
(1) PCIe x16
(1) PCIe x1
(1) PCI
(1) M.2 (for optional WLAN module)
(1) M.2 2230/2280 storage (PCIe x4)
Bays
(1) 8.89 cm (3.5 in) Hard disc drive bay
(1) 8.89 cm (3.5 in) Hard disc drive bay (internal shared bay)
(1) 13.33 cm (5.25 in) Optical disc drive bay (external slimline)
(1) SD card reader bay
Networking
Specification
Ethernet (RJ45)
Integrated 10/100/1000M GbE LAN
Wireless
Intel 802.11a/b/g/n/ac (1x1) WiFi and Bluetooth 4.2 Combo
Wireless cards are optional or add-on features and requires separately purchased wireless access point and internet service. Availability of public wireless access points limited.
Software/security
Specification
Preinstalled software (varies by country/region)
HP ePrint and JetAdvantage
Requires an Internet connection to HP web-enabled printer and HP ePrint account registration. Requires optional broadband module. Broadband use requires separately purchased service contract. Check with service provider for coverage and availability in your area. Separately purchased data plans or usage fees might apply. Print times and connection speeds might vary.
Buy Office
HP JumpStart
Windows 10 Redstone 1 Recovery Manager Installer - CPS
Windows 10 Redstone 1 Push Button Reset Recovery - CPS
HP Support Assistant
HP PC Hardware Diagnostics UEFI
HP System Event Utility
Bing Search for IE
Security lock slot (locks sold separately)
McAfee LiveSafe (only available in Brazil, Chile, and Argentina)
Security
Trusted Platform Module (TPM) 2.0
Yes (2 Watts)
Power
Specification
180 W (internal power supply)
Up to 90% efficiency
Active PFC
310 W (internal power supply)
Active PFC
Available in selected countries/regions only.
Physical features
Specification
Chassis (H x W x D)
16.99 x 33.78 x 27.74 cm (6.69 x 13.3 x 10.92 in)
5.4 kg (11.90 lb)
As configured with (1) HDD and (1) ODD. Weight varies by configuration.
