    Fix Windows 10 Update Issues
HP Spectre x360 - 13-ae054tu Product Specifications
3AH51PA
Intel® Core™ i7-8550U (1.8 GHz base frequency, up to 4 GHz with Intel® Turbo Boost Technology, 8 MB cache, 4 cores)
16 GB LPDDR3-2133 SDRAM (onboard)
Video graphics
Intel® UHD Graphics 620
360 GB PCIe® NVMe™ M.2 SSD
13.3" diagonal FHD IPS micro-edge WLED-backlit touch screen with Corning® Gorilla® Glass NBT™ (1920 x 1080)
Keyboard
Full-size island-style backlit keyboard
Pointing device
Intel® 802.11a/b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo
1 microSD media card reader
2 Thunderbolt™ 3 (Data Transfer up to 40 Gb/s, Power Delivery, DP1.2, HP Sleep and Charge); 1 USB 3.1 Gen 1 (HP Sleep and Charge); 1 headphone/microphone combo
Dimensions (W x D x H)
30.6 x 21.8 x 1.36 cm
Starting at 1.26 kg
65 W AC power adapter
3-cell, 60 Wh Li-ion polymer
HP TrueVision FHD IR Camera with integrated dual array digital microphone
Bang & Olufsen, quad speakers, HP Audio Boost
HP Audio Switch; HP Documentation; HP ePrint; HP JumpStart; HP Recovery Manager; HP Support Assistant; HP Sure Connect
