    Fix Windows 10 Update Issues
HP PageWide Enterprise MFP, HP PageWide Managed MFP - Energy-conservation settings
Configure sleep settings to reduce power usage when the printer is idle.
Video
If you have trouble viewing the video, or to view the video in a different size, click here to play the video on YouTube.
Set the sleep timer and configure the printer to use 2 watts or less of power
The sleep settings affect how much power the printer uses, the wake/sleep time, how quickly the printer enters sleep mode, and how quickly the printer wakes up from sleep mode.
To configure the printer to use 2 watts or less of power while in sleep mode, enter times for both the Sleep after Inactivity and Auto Off after sleep settings.
  1. From the Home screen on the printer control panel, select Settings.
  2. Open the following menus:
    • General
    • Energy Settings
    • Sleep Settings
  3. Select Sleep after Inactivity to specify the number of minutes the printer is inactive before it enters sleep mode. Enter the appropriate time period.
  4. Select Auto Off after sleep to put the printer into a deeper power save mode after a period of sleep. Enter the appropriate time period.
    By default, the printer will wake from Auto Off in response to any activity other than USB or Wi-Fi. For greater energy settings, you can set it to wake only to the power button by selecting Shut down (wake on power button only).
  5. Select Done to save the settings.
Set the sleep schedule
Use the Sleep Schedule feature to configure the printer to automatically wake or go into Sleep mode at specific times on specific days of the week.
    • General
    • Energy Settings
    • Sleep Schedule
  3. Select the New Event button, and then select the type of event to schedule: Wake Event or Sleep Event.
  4. For a wake or sleep event, configure the time and the days of the week for the event. Select Save to save the setting.
