HP EliteBook 850 G5 Notebook PC Specifications
Product image
Figure : HP EliteBook 850 G5 Notebook PC
Operating systems
Specification
Preinstalled
Windows 10 Pro 641
Windows 10 Home 641
FreeDOS 1.2
1Not all features are available in all editions or versions of Windows. Systems might require upgraded and/or separately purchased hardware, drivers, software or BIOS update to take full advantage of Windows functionality. Windows 10 automatic updates are always enabled. ISP fees might apply and additional requirements might apply over time for updates.
In accordance with Microsoft support policy, this product does not support Windows 8 or Windows 7. HP does not support the Windows 8 or Windows 7 operating system on products configured with Intel and AMD 7th generation or later processors, or provide any Windows 8 or Windows 7 drivers.
Processors
Specification
Intel Core i5-7200U
2.5 GHz base frequency, up to 3.1 GHz with Intel Turbo Boost Technology
3 MB cache and 2 cores
Intel HD Graphics 620
Intel Core i5-7300U
2.6 GHz base frequency, up to 3.5 GHz with Intel Turbo Boost Technology
Intel Core i5-8250U
1.6 GHz base frequency, up to 3.4 GHz with Intel Turbo Boost Technology
6 MB cache and 4 cores
Intel UHD Graphics 620
Intel Core i5-8350U
1.7 GHz base frequency, up to 3.6 GHz with Intel Turbo Boost Technology
Intel Core i7-8550U
1.8 GHz base frequency, up to 4.0 GHz with Intel Turbo Boost Technology
8 MB cache and 4 cores
Intel Core i7-8650U
1.9 GHz base frequency, up to 3.9 GHz with Intel Turbo Boost Technology
Integrated with processor
Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. Performance and clock frequency vary depending on application workload and hardware and software configurations. Intel numbering is not a measurement of higher performance.
Processor speed denotes maximum performance mode; processors run at lower speeds in battery optimization mode.
Graphics
Specification
Integrated
Discrete
AMD Radeon R59 (sold separately or as an optional feature)
AMD Dynamic Switchable Graphics technology requires an Intel processor, plus an AMD Radeon discrete graphics configuration and is not available on FreeDOS and Linux OS. With AMD Dynamic Switchable Graphics technology, full enablement of all discrete graphics video and display features might not be supported on all systems (e.g. OpenGL applications will run on the integrated GPU or the APU as the case may be).
Supported
Supports HD decode, DX12, and HDMI 1.4b
HDMI cable sold separately.
High-definition (HD) content is required to view high definition images.
Specification
Non-touch1
39.6 cm (15.6 in) diagonal FHD IPS anti-glare LED-backlit, 220 cd/m2, 45% sRGB (1920 x 1080)
39.6 cm (15.6 in) diagonal FHD IPS anti-glare LED-backlit, 220 cd/m2, 45% sRGB with HD camera (1920 x 1080)
39.6 cm (15.6 in) diagonal FHD IPS anti-glare LED-backlit, 220 cd/m2, 45% sRGB with HD IR camera (1920 x 1080)
39.6 cm (15.6 in) diagonal FHD IPS anti-glare LED-backlit, 220 cd/m2, 45% sRGB for WWAN (1920 x 1080)
39.6 cm (15.6 in) diagonal FHD IPS anti-glare LED-backlit, 220 cd/m2, 45% sRGB with HD camera for WWAN (1920 x 1080)
39.6 cm (15.6 in) diagonal FHD IPS anti-glare LED-backlit, 220 cd/m2, 45% sRGB with HD IR webcam for WWAN (1920 x 1080)
39.6 cm (15.6 in) diagonal FHD IPS anti-glare LED-backlit, 400 cd/m2, 72% sRGB with ambient light sensor and HD IR webcam (1920 x 1080)
39.6 cm (15.6 in) diagonal FHD IPS anti-glare LED-backlit, 400 cd/m2, 72% sRGB with ambient light sensor and HD IR webcam for WWAN (1920 x 1080)
39.6 cm (15.6 in) diagonal 4K IPS anti-glare LED-backlit, 400 cd/m2, 72% sRGB with ambient light sensor and HD IR webcam for WWAN (3840 x 2160)
HP Sure View Integrated Privacy Screen 39.6 cm (15.6 in) diagonal FHD IPS anti-glare LED-backlit, 700 cd/m2, 72% sRGB with HD IR webcam for WWAN (1920 x 1080)
HP Sure View is optional and must be configured at purchase.
Touch1
39.6 cm (15.6 in) diagonal FHD IPS LED-backlit touch screen with Corning Gorilla Glass 3, 220 cd/m2, 45% sRGB with HD IR camera (1920 x 1080)
39.6 cm (15.6 in) diagonal FHD IPS LED-backlit touch screen with Corning Gorilla Glass 3, 220 cd/m2, 45% sRGB with HD IR webcam for WWAN (1920 x 1080)
HP Sure View Integrated Privacy Screen 39.6 cm (15.6 in) diagonal FHD IPS LED-backlit touch screen with Corning Gorilla Glass 3, 700 cd/m2, 72% sRGB with HD IR webcam for WWAN (1920 x 1080)
HDMI 1.4b
Supports resolution up to 4k at 60 Hz
Displays supported
Supports 2 independent displays when docked on the HP Ultraslim Dock
1Sold separately or as an optional feature.
Resolutions are dependent upon monitor capability, and resolution and color depth settings.
Memory
Specification
Standard
DDDR4-PC4 SODIMMS
(2) Dual-channel SODIMM slots (both slots are customer accessible/upgradable)
Runs at 2133 MT/s for Intel 7th generation processors
Runs at 2400 MT/s for Intel 8th generation processors
Configurations
32 GB DDR4-2400 SDRAM (16 GB x 2)
16 GB DDR4-2400 SDRAM (16 GB x 1)
16 GB DDR4-2400 SDRAM (8 GB x 2)
8 GB DDR4-2400 SDRAM (8 GB x 1)
8 GB DDR4-2400 SDRAM (4 GB x 2)
4 GB DDR4-2400 SDRAM (4 GB x 1)
Maximum
32 GB
Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility. If memory speeds are mixed, the system performs at the lower memory speed.
Storage/drives
Specification
Primary M.2 storage
128 GB SATA-3 TLC Solid State Drive
256 GB PCIe NVMe Value TLC Solid State Drive
256 GB PCIe Gen 3x4 NVMe TLC Solid State Drive
256 GB SATA-3 TLC Opal 2 Solid State Drive
360 GB PCIe Gen 3x4 NVMe TLC Solid State Drive (Intel)
512 GB PCIe Gen 3x4 NVMe TLC Solid State Drive
512 GB PCIe Gen 3x4 NVMe TLC Opal 2 Solid State Drive
512 GB SATA-3 TLC FIPS-140-2 Solid State Drive
1 TB PCIe Gen 3x4 NVMe TLC Solid State Drive
1For solid state drives or hard drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 30 GB (for Windows 10) is reserved for system recovery software.
Ports/slots
Specification
Ports
(1) Thunderbolt (USB Type-C connector)
(2) USB 3.1 Gen 1 (1 charging)
(1) HDMI 1.4b port (cable sold separately)
(1) RJ-45/Ethernet port
(1) Docking connector
(1) Headphone/microphone combo jack
(1) AC power port
Slot
(1) SIM card slot
(1) Smart card reader
Networking/communication
Specification
Wireless LAN (WLAN)
Intel Dual Band Wireless-AC 8265 802.11a/b/g/n/ac (2x2) Wi-Fi and Bluetooth 4.2 Combo, vPro
Intel Dual Band Wireless-AC 8265 802.11a/b/g/n/ac (2x2) Wi-Fi and Bluetooth 4.2 Combo, non-vPro
Realtek RTL8822BE 802.11ac (2x2) Wi-Fi and Bluetooth 4.2 Combo, non-vPro
Wireless access point and Internet service is required and is not included. Availability of public wireless access points limited. The specifications for the 802.11ac WLAN are draft specifications and are not final. If the final specifications differ from the draft specifications, it might affect the ability of the notebook to communicate with other 802.11ac WLAN devices.
WWAN
HP lt4132 LTE/HSPA+ 4G Mobile Broadband
Intel XMM 7360 LTE-Advanced
WWAN use requires separately purchased service contract. Check with service provider for coverage and availability. Connection speeds varies due to location, environment, network conditions, and other factors. 4G LTE not available on all products, and in all countries/regions.
Near Field Communication (NFC)
NXP NPC300 Near Field Communication module
Ethernet
Intel I219-LM 10/100/1000 GbE, vPro
Intel I219-V 10/100/1000 GbE, non-vPro
The term "10/100/1000" or "Gigabit" Ethernet indicates compatibility with IEEE standard 802.3ab for Gigabit Ethernet, and does not connote actual operating speed of 1 Gb/s. For high-speed transmission, connection to a Gigabit Ethernet server and network infrastructure is required.
Audio/multimedia
Specification
Audio
Audio by Bang & Olufsen
(3) Integrated multi-array microphone
(2) Integrated stereo speakers (74 dB)
Camera
HD camera
HD IR camera
HD content required to view HD images. Internet access required.
Keyboards/pointing devices/function keys
Specification
HP Premium keyboard
Spill-resistant with drain (thin layer of Mylar film under the keyboard)
Backlit (optional)
Pointing devices
Clickpad with multi-touch gestures enabled (taps enabled as default)
Microsoft Precision Touchpad default gestures supported
Buttons
Share/present
Call answer
Call end
Function keys
Function keys
F1 – Display switching
F2 – Blank or privacy
F3 – Brightness down
F4 – Brightness up
F5 – Audio mute
F6 – Volume down
F7 – Volume up
F8 – Microphone mute
F9 – Backlight toggle (for backlit keyboard) or blank
F10 – Numlk
F11 – Wireless
F12 – Calendar
Hidden fuctions
Fn+R – Break
Fn+S – Sys Rq
Fn+C – Scroll Lock
Software/security
Specification
BIOS
HP BIOSphere Gen4 (requires Intel 8th generation processors)
HP Sure Start Gen4 (requires Intel 8th generation processors)
BIOS Update via Network
Master Boot Record Security
Power On Authentication
Secure Erase (methods outlined in the National Institute of Standards and Technology Special Publication 800-88)
Absolute Persistence Module1
Pre-boot Authentication
HP Wireless Wakeup
Communication/connectivity
HP Native Miracast support
HP LAN-WLAN Protection
HP Value add software
HP Velocity v1.5
HP ePrint Driver with JetAdvantage2
HP Hotkey Support - CMIT
HP Recovery Manager
HP Jumpstart
HP Support Assistant (requires Windows and internet access)
HP Noise Cancellation software
HP Performance Advisor
Ivanti Management Suite (subscription required)
Microsoft products
Buy Office
Manageability
HP Driver packs (available for download)
HP SoftPaq Download Manager (SDM)
HP System Software Manager (SSM) (available for download)
HP BIOS Configuration Utility (BCU) (available for download)
HP Client Catalog (available for download)
HP Management Integration Kit for Microsoft SCCM (available for download)
HP Image Assistant
For more information about manageability software, go to the HP Client Management Solutions webpage.
Client Security software
Microsoft Defender (opt in and internet connection required for updates)
HP Client Security Suite Gen4 (requires Windows)
HP Security Manager (including Credential Manager and HP Password Manager, and HP Spare Key)
HP Fingerprint Sensor (sold separately or as an optional feature)
HP Device Access Manager
HP Sure Click (supports Microsoft Internet Explorer and Chromium)
HP Sure Run (requires 8th generation processors)
HP Sure Recover (requires 8th generation processors)
Security
For Windows 10, Trusted Platform Module (TPM) 2.0 (Infineon SLB9670)
Common Criteria EAL4+ Certified
HP Fingerprint Reader
For more information about security software and features, go to the HP Client Security Software Suite webpage.
Other standard security features
SATA 0 and 1 port disablement (via BIOS)
RAID (optional and requires a second hard drive)
Serial, USB enable/disable (via BIOS)
Power-on password (via BIOS)
Setup password (via BIOS)
Support for chassis padlocks and cable lock devices
Security lock slot (lock sold separately)
1Absolute agent is activated when customers activate a purchased subscription. Subscriptions can be purchased for terms ranging multiple years. Service is limited, check with Absolute for availability outside the U.S. The Absolute Recovery Guarantee is a limited warranty. Certain conditions apply. Data Delete is an optional service provided by Absolute Software. If utilized, the Recovery Guarantee is null and void. In order to use the Data Delete service, customers must first sign a Pre-Authorization Agreement and either obtain a PIN or purchase one or more RSA SecurID tokens from Absolute Software.
2Requires an Internet connection to HP web-enabled printer and HP ePrint account registration. Requires optional broadband module. Broadband use requires separately purchased service contract. Check with service provider for coverage and availability in your area. Separately purchased data plans or usage fees might apply. Print times and connection speeds might vary.
HP Cloud Recovery download tool (Cloud Recovery Client) is available under Software and Drivers section on the support page.
Power
Specification
Power supply
Adapters
HP Smart 45 W External AC power adapter
HP Smart 45 W External AC power adapter, 2-prong (Japan only)
HP Smart 65 W External AC power adapter
HP Smart 65 W EM External AC power adapter
45 W USB Type-C adapter
65 W USB Type-C adapter
Availability might vary by country/region.
Power cord
1.8 m (5.91 ft) 3-wire plug
1.0 m (3.28 ft) 3-wire plug
1.0 m (3.28 ft) 2-wire plug (2-prong Japan only)
Duckhead power cord 1.0 m (3.28 ft)
Duckhead power cord 1.8 m (5.91 ft)
Primary battery
HP 3-cell 50 Wh Long Life Li-ion
Battery is internal and not replaceable by customer.
Weight/dimensions
Specification
Non-touch
Starting at 1.78 kg (3.92 lb)
Touch
Starting at 1.93 kg (4.25 lb)
Weight varies by configuration and components.
Dimensions (W x D x H)
Non-touch
37.08 x 25.17 x 1.83 cm (14.60 x 9.91 x 0.72 in)
Touch
37.08 x 25.17 x 1.85 cm (14.60 x 9.91 x 0.73 in)
