Data transfer rates up to 3,600 KB/s (CD read/write)
Data transfer rates up to 10,800 KB/s (DVD read/write)
Formats/Disc types
Write speeds
Read speeds
DVD
DVD-ROM SL
N/A
up to 8x
DVD-ROM DL
N/A
up to 8x
DVD+R SL
up to 8x
up to 8x
DVD+R DL
up to 6x
up to 8x
DVD-R SL
up to 8x
up to 8x
DVD-R DL
up to 6x
up to 8x
DVD+RW
up to 8x
up to 8x
DVD-RW
up to 6x
up to 8x
CD
CD-R
up to 24x
up to 24x
CD-RW
up to 10x
up to 24x
CD-ROM
N/A
up to 24x
Memory card reader
3-in-1 Memory card reader
Figure : Memory card reader
Supports the following cards:
Secure Digital (SD)
Secure Digital High Capacity (SDHC)
SDXC
Computer case
All-in-One
Height: 45.7 cm
(18.0 in)
Width: 57.2 cm (22.5 in)
Depth: 17.0 cm (6.7 in)
Weight: 7.80 kg (17.20 lbs) unpackaged
Front of the system
Figure : Front of the system
Webcam and microphones
Screen
Optical disk drive
Power button
HDMI source button
Bottom I/O ports
Speakers
Back of the system
Figure : Back of the system
Optical disk drive
Security lock slot
Back I/O ports
Stand
Right side of the system
Figure : Right side of the system
Optical disk drive
Power supply
External 150 W PSU
Total wattage: 150 W
Output voltage: 19.5 V
Efficiency: 89%
I/O ports
Back I/O ports
The configuration might vary depending on your model.
Figure : Back I/O ports
Security lock slot
USB 2.0: 2
USB 3.1-Type A
USB 3.1-Type A charging
DC power in
Power indicator LED
HDMI out
HDMI in
LAN (Ethernet)
Disk activity LED
Bottom I/O ports
Figure : Bottom I/O ports
USB 3.1-Type C
Headphone/Microphone
Memory card reader
Keyboard, mouse and input devices
HP USB wired keyboard with volume control
Cable: 1.9 m (6.2 ft)
Dimensions (approximate):
Height: 14.4 cm (5.7 in)
Width: 41.0 cm (16.1 in)
Depth: 2.23 cm (0.9 in)
Special keys:
Mute
Volume down
Volume up
Previous track
Play/Pause
Next track
Brightness down
Brightness up
Calculator
HP USB wired optical mouse
Cable: 2.0 m (6.6 ft)
Travel distance: 0.5 mm +/- 0.25 mm
Weight (approximate): 90 g
Height: 11.9 cm (4.7 in)
Width: 6.5 cm (2.6 in)
Depth: 3.2 cm (1.3)
HP Privacy FHD Camera
Figure : HP Privacy FHD Camera
Camera
Webcam activity LED
Webcam microphones
Titles that shipped with PC
HP provides basic support for software that comes with the computer. For in-depth feature assistance, refer to the help section in the software or on the software vendor's Web site.
Software Category
Software Title
Recovery Manager: Program Reinstallation
Operating System
Microsoft Windows 10 Home (64-bit)
No
Entertainment, Music & Games
Booking.com
B&O Play
CyberLink Power Media Player
HP Audio Switch
HP Games
Netflix
Solitaire
No
No
No
Yes
No
No
No
Productivity
Dropbox
HP Jumpstart
HP Jumpstart Apps
No
No
No
Imaging, Photography, Video & Film
HP ePrint
No
HP Display Control
Yes
Security
McAfee LiveSafe (30-day subscription)
No
Support
HP Documentation
HP PC Hardware Diagnostics UEFI
HP Support Assistant
Yes
Yes
Yes
Recovery
HP Recovery Manager
No
Browser
Microsoft Edge
No
This support document provides specifications and component images that reflect the original design intention for all PCs of this model. Under certain circumstances, a factory or service provider may install a component that meets or exceeds the listed specification and/or appears different than the image shown.
Some features of the tool may not be available at this time. We apologize for this inconvenience and are addressing the issue.Minimize Chat bot windowLoading ChatbotNew Message
