    Fix Windows 10 Update Issues
    Are you working from home?
Samsung ProXpress SL-C2620 Color Laser Printer - Loading Paper in the Tray
This document explains how to load paper in the tray.
Tray overview
To change the size, users need to adjust the paper guides.
    Figure : Paper tray
  1. Tray extend lever
  2. Paper length guide
  3. Paper width guide
For Legal-sized paper: Push button as shown and pull out the tray.
Figure : Tray adjustment
Illustrations on this user’s guide might differ from the printer depending on its options or models. Check the printer type.
If users do not adjust the guide, it might cause paper registration, image skew, or jamming of the paper.
Loading paper in the tray
  1. Pull out the paper tray.
    Figure : Paper tray, remove
  2. Squeeze and the paper width guide and paper length lever to locate them in the correct paper size slot marked at the bottom of the tray to adjust to the size.
    Figure : Adjust paper guides
  3. Flex or fan the edge of the paper stack to separate the pages before loading papers.
    Figure : Flex or fan paper
  4. After inserting paper into the tray, squeeze the paper width guides and paper length guide.
    1. Paper length guide
    2. Paper width guide
    • Do not push the paper width guide too far causing the paper to warp.
    • If users do not adjust the paper width guide, it might cause paper jams.
      Figure : Correct guide adjustment
    • Do not use a paper with a leading-edge curl, it might cause a paper jam or the paper can be wrinkled.
      Figure : Non-curled or wrinkled paper
  5. Insert the tray back into the printer.
    Figure : Paper tray, insert
  6. When users print a document, set the paper type and size for the tray.
Multipurpose tray
The multi-purpose tray can hold special sizes and types of print material, such as postcards, note cards, and envelopes.
Tips on using the multipurpose tray
  • Load only one type, size and weight of print paper at a time in the multipurpose tray.
  • To prevent paper jams, do not add paper while printing when there is still paper in the multipurpose tray. This also applies to other types of print paper.
  • Always load the specified print paper only to avoid paper jams and print quality problems.
  • Flatten any curl on postcards, envelopes, and labels before loading them into the multipurpose tray.
  1. Press the push-release of multipurpose tray and pull it down to open.
    Figure : Multipurpose tray, open
  2. Load the paper.
    Figure : Paper, insert
  3. Squeeze the multipurpose tray paper width guides and adjust them to the width of the paper. Do not force them too much, or the paper will bend resulting in a paper jam or skew.
    • When printing the special paper, users must follow the loading guideline.
    • When papers overlap when printing using the multipurpose tray, open Tray 1 and remove the overlapping papers then try printing again.
  4. When users print a document, set the paper type and size for the multipurpose tray.
