Samsung CLX-2160 Color Laser MFP - Loading Originals
This document provides instructions on how to load originals into the printer.
Load originals
You can use the scanner glass to load an original for copying, scanning.
  1. Lift and open the scanner lid.
    Figure : Example of lifting and opening the scanner lid
  2. Place the original face down on the scanner glass and align it with the registration guide at the top left corner of the glass.
    Figure : Example of placing the original face down on scanner glass
  3. Close the scanner lid. Be careful not to move the document.
    When you close the scanner lid after placing the document, be careful your fingers not to be caught between the scanner glass and the lid. Your printer\ may have a heavy lid (or cover) for optimal pressure on the document for the best scanning.
    • Leaving the scanner lid open while copying may affect copy quality and toner consumption.
    • Dust on the scanner glass may cause black spots on the printout. Always keep it clean.
    • If you are copying a page from a book or magazine, lift the scanner lid until its hinges are caught by the stopper and then close the lid. If the book or magazine is thicker than 30 mm, start copying with the lid open.
