    Fix Windows 10 Update Issues
    Are you working from home?
HP ChromeBook 14 G5 Specifications
Product image
Figure : HP ChromeBook 14 G5
HP ChromeBook 14 G5
Feature
Preinstalled
Chrome OS
Processor
Intel Celeron N3060
1.1 GHz base frequency, 2.4 GHz burst frequency
2 MB cache
2 cores
Intel HD Graphics 500
Intel Celeron N3450
1.1 GHz base frequency, 2.2 GHz burst frequency
2 MB cache
4 cores
Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. Performance and clock frequency vary depending on application workload and hardware and software configurations. Intel numbering is not a measurement of higher performance.
Graphics
Feature
Integrated
High-definition (HD) content is required to view high definition images.
Feature
Non-touch
35.56 cm (14.0 in) diagonal HD SVA anti-glare WLED-backlit, 220 cd/m2, 72% sRGB (1366 x 768)
35.56 cm (14.0 in) diagonal FHD IPS anti-glare WLED-backlit, 220 cd/m2, 72% sRGB (1920 x 1080)
Touch
35.56 cm (14.0 in) diagonal HD SVA Brightview WLED-backlit, touchscreen, 220 cd/m2, 72% sRGB (1366 x 768)
35.56 cm (14.0 in) diagonal FHD IPS Brightview WLED-backlit, 220 cd/m2, 72% sRGB (1920 x 1080)
FHD IPS touchscreen for collaboration is optional or sold seprately.
High definition content is required to view high-definition images.
Resolutions are dependent upon monitor capability, resolution, and color depth settings.
Storage and drives
Feature
Primary storage (supports eMMC SSD)
eMMC 5.0
16 GB
32 GB
64 GB
Actual formatted capacity is less. 5.1 GB of the eMMC is dedicated/allocated to the Chrome OS partition.
Secondary storage
Stores up to 100 GB with Google Drive (2-year subscription included)
This offer is tied to this device and is non-transferable. If this device is returned, the extra storage is revoked. Chrome OS 23 or later is required to redeem this offer. Internet access required and not included. For more information about storage plan refunds, renewals, and cancellations and expiration go to the Google webpage.
Memory
Feature
Soldered memory
4 GB LPDDR4-2400 SDRAM
8 GB LPDDR4-2400 SDRAM
Maximum memory
8 GB
Ports/slots
Specification
Ports
(2) USB 3.1 Type-C
(2) USB 3.1 Gen 1 (sleep and charge support)
(1) Headphone/microphone combo jack
Slots
(1) MicroSD card
Supports SD, SDHC, and SDXC.
Audio/multimedia
Feature
Audio
HD audio
Dual speakers
Integrated dual-array microphone
Camera
720p HD camera
High definition content required to view high-definition images.
Keyboard/pointing devices
Keyboard
Full-sized island-style
Spill resistant
Pick resistant
Backlit (optional)
Pointing devices
Touchpad
Multitouch gestures enabled
Taps enabled as default
Networking/communication
Feature
Wireless LAN (WLAN)
Intel Dual Band Wireless-AC 7265 802.11a/b/g/n/ac (2x2) WiFi and Bluetooth 4.2 Combo, non-vPro
Integrated wireless options with dual antennas
Wireless access point and Internet service required and sold separately. Availability of public wireless access points limited. The specifications for the 802.11ac WLAN are draft specifications and are not final. If the final specifications differ from the draft specifications, it might affect the ability of the notebook to communicate with other 802.11ac WLAN devices.
Software and security
Preinstalled software
HP Classroom Manager
Security
H1 Security IC
Nano Security lock slot (lock sold separately)
Power
Specification
Power supply
HP 45W USB Type-C AC Adapter (straight type )
Power cord
Minimum 2.6 m (8.53 ft) length USB-C/power cord
Primary battery
HP Long Life 2-cell, 47.36 Wh Li-ion
Battery is internal and not replaceable by customer. Serviceable by warranty.
Battery life
Up to 10 hours
Testing conducted by HP using Google Chrome OS power_LoadTest based on PV result (configuration is Intel DC/HD panel/4 GB memory/64 GB storage using Power_load test, battery life might vary for different configurations). Battery life varies and the maximum capacity of the battery naturally decreases with time and usage.
Physical features
Specification
Starting at 1.54 kg (3.39 lb)
Dimensions (W x D x H)
46.61 x 22.68 x 1.83 cm (18.35 x 8.93 x 0.72 in)
