    Are you working from home?
    Fix Windows 10 Update Issues
Samsung Xpress SL-M3015 Laser Printer - Replacing the Imaging Unit
This document explains how to replace the imaging unit for the Samsung Xpress SL-M3015 Laser Printer.
When the life span of the imaging unit has expired, the Smart Panel program window appears on the computer, indicating the imaging unit needs to be placed. Otherwise, the printer stops printing.
  • Do not use sharp objects such as a knife or scissors to open the imaging unit package. They might scratch the surface of the imaging unit.
  • Do not touch the green area of the imaging unit. Use the handle on the imaging unit to avoid touching this area.
  • To prevent damage, do not expose the imaging unit to light for more than a few minutes. Cover it with a piece of paper to protect it if necessary.
  • Before closing the front cover, make sure all toner cartridges are installed properly.
Replacing the imaging unit
Use these steps to replace the imaging unit.
  1. Press the cover release button, and then open the front cover.
    Figure : Example of pressing cover release button, and then opening front cover
  2. Grasp the handles of the toner cartridge, and then remove from the printer.
    Figure : Example of grasping the toner cartridges
  3. Grasp the imaging unit, and then removing from the printer.
    Figure : Example of grasping the imaging unit to remove
  4. Remove the new imaging unit from its box, and then remove all plastic packaging.
    Figure : Example of removing the new imaging unit from box, and then remove packaging
  5. Reinsert the imaging unit.
    Figure : Example of reinserting the imaging unit
  6. Insert toner cartridge (1), and then close the front cover (2).
    Figure : Example of inserting the toner cartridge (1), and then closing the front cover (2).
