Samsung Xpress SL-M3015 Laser Printer - Replacing the Toner Cartridge
This document explains how to replace the toner cartridge for the Samsung Xpress SL-M3015 Laser Printer.
A toner cartridge has almost reached its estimated cartridge life:
  • The status LED and the toner-related message on the display indicate when the toner cartridge should be replaced.
  • The computer’s Samsung Printing Status program window appears on the computer telling you which cartridge is low on toner.
      warning:
    • To prevent damage to the toner cartridge, do not expose it to light for more than a few minutes. Cover it with a piece of paper, if necessary.
    • Do not touch the green area of the toner cartridge. Use the handle on the cartridge to avoid touching this area.
    • Do not use sharp objects such as a knife or scissors to open the toner cartridge package. They might scratch the drum of the cartridge.
    • If toner gets on your clothing, wipe it off with a dry cloth and wash clothing in cold water. Hot water sets toner into fabric.
    • Before opening the front cover, close the output support first.
    • Shake the toner cartridge thoroughly side to side, it will increase the initial print quality.
Replacing the toner cartridges
Use these steps to replace the toner cartridges.
  1. Press the cover release button, and then open the front cover.
    Figure : Example of pressing the cover release button
  2. Grasp the handle of the toner cartridge, and then remove from the printer.
    Figure : Example of grasping the toner cartridges
  3. Remove the new toner cartridge from the box. Gently shake toner side to side to distribute evenly.
    Figure : Example of removing new toner cartridge, and then gently shaking
  4. Remove all packaging materials, and then recycle.
    Make sure to recycle all packaging materials.
    Figure : Example of removing packaging material
  5. Insert the toner cartridge into the correct slot.
    Figure : Example of inserting new toner cartridge
  6. Close the front cover.
    Figure : Example of closing the front cover
