Samsung Laser Printers - Loading Paper
This document provides instructions on how to load paper into the paper tray for the Samsung SL- M3870, M3375, M4070, M3370, M4072, M3875, M4075 Laser Printers.
Illustrations in this user’s guide may differ from your printer depending on the model and options installed.
Printing on special media
The paper setting in the printer and driver should match to print without a paper mismatch error.
To change the paper setting set in the printer, from the Samsung Easy Printer Manager select (Switch to advanced mode)> Device Settings.
Or if your printer supports a display screen or touch screen, you can set it from the control panel. Then, set the paper type from the Printing preferences window > Paper tab > Paper Type. For example, if you want to print on labels, select Labels for Paper Type.
  • When using special media, feed one sheet at a time.
  • Illustrations in this user’s guide may differ from your printer depending on the model and options installed.
Refer to the table for special media uses in the tray.
Types
Tray 1
Optional traya
Multi-purpose (manual feeder) tray
Plain
Thick
Thicker
Thin
Bond
Cotton
Envelope
Color
Cardstock
Labels
Preprinted
Recycled
Archive
a. optional device
(·: Supported, Blank: Not supported)
The media types are shown in the Printing Preferences. This paper type option allows you to set the type of paper to be loaded in the tray. This setting appears in the list so that you can select it. This will let you get the best quality printout. If not, the desired print quality may not be achieved.
