Samsung SCX-6122, SCX-6322 Laser MFP - Loading Originals
This document explains how to load original documents.
Users can use the scanner glass or ADF to load an original for copying, scanning, and sending a fax.
On the scanner glass
Make sure that no originals are in the ADF. If an original is detected in the ADF, the printer gives it priority over the original on the scanner glass. To get the best scan quality, especially for colored or gray-scaled images, use the scanner glass.
  1. Lift and open the scanner lid.
    Figure : Scanner lid, open
  2. Place the original face down on the scanner glass and align it with the registration guide at the top left corner of the glass.
    Figure : Place original
  3. Close the scanner lid.
    • Leaving the scanner lid open while copying might affect copy quality and toner consumption.
    • Dust on the scanner glass might cause black spots on the printout. Always keep it clean.
    • If users are copying a page from a book or magazine, lift the scanner lid until its hinges are caught by the stopper and then close the lid. If the book or magazine is thicker than 30 mm, start copying with the lid open.
In the ADF
Using the ADF, users can load up to 40 sheets of paper (75 g/m2) for one job, (SCX-6122FN only).
In case of the SCX-6322DN, 50 sheets of paper (75 g/m2) can be loaded for one job.
When using the ADF:
  • Do not load paper smaller than 142 x 148 mm or larger than 216 x 356 mm. In case of the SCX-6122FN, make sure that users do not load paper smaller than 172 x 148 mm.
  • Do not attempt to load the following types of paper:
    • carbon-paper or carbon-backed paper
    • coated paper
    • onion skin or thin paper
    • wrinkled or creased paper
    • curled or rolled paper
    • torn paper
  • Remove all staples and paper clips before loading.
  • Make sure any glue, ink, or correction fluid on the paper is completely dry before loading.
  • Do not load originals that include different sizes or weights of paper.
  • Do not load booklets, pamphlets, transparencies, or documents having other unusual characteristics.
To load an original into the ADF:
  1. Load the original face up into the ADF. Make sure that the bottom of the original stack matches the paper size marked on the document input tray.
  2. Adjust the document width guides to the paper size.
    Figure : Width guides, adjust
    Dust on the ADF glass might cause black lines on the printout. Always keep it clean.
