    Fix Windows 10 Update Issues
    Are you working from home?
Samsung SCX-5835, SCX-5935 Laser MFP - Replacing the Toner Cartridge
This document explains how to replace the toner cartridge.
When a toner cartridge has reached the end of life:
  • Toner is low. Order new toner cartridge displays on the control panel.
  • The Status LED blinks red.
At this stage, the toner cartridge needs to be replaced. Check the type of toner cartridge for your printer.
Replacing the toner cartridge
Use these steps to replace the toner cartridge.
  1. Turn the printer off, then wait a few minutes for it to cool.
  2. Open the front cover.
  3. Pull the toner cartridge out.
    Figure : Remove the used toner cartridge
  4. Remove the new toner cartridge from its packaging.
  5. Remove the packing tape and roll the cartridge 5 or 6 items to distribute the toner.
    Figure : Rock the toner cartridge gently side to side
    Thoroughly roll the cartridge to assure maximum copies per cartridge. Save the box and the plastic bag for shipping.
    If toner gets on clothing, wipe it off with a dry cloth and wash it in cold water. Hot water sets toner into fabric.
    Do not touch the green underside of the toner cartridge. Use the handle on the cartridge to avoid touching this area.
  6. Hold the toner cartridge by the handle and slowly insert the cartridge into the opening in the printer.
    Tabs on the sides of the cartridge and corresponding grooves within the printer will guide the cartridge into the correct position until it locks into place completely.
    Figure : Install the replacement toner cartridge
  7. Close the front cover. Make sure the cover is securely latched, and then turn the printer on.
    Figure : Close the front cover
