Samsung CLX-3180, CLX-3185, CLX-3186 Color Laser MFP - Replacing the Waste Toner Container
This document explains how to replace the waste toner container. When the life span of the waste toner container has expired, the Smart Panel program window appears on the computer, indicating the waste toner container needs to be replaced. Otherwise the printer stops printing.
Do not tilt or turn over the container.
Replacing the waste toner container
Use these steps to replace the waste toner container.
  1. Turn the printer off, then wait a few minutes for the printer to cool.
  2. Using the handle, completely open the front door.
    Figure : Front door, open
  3. Pull the waste toner container out of the printer using its handle.
    Figure : Waste toner container, remove
    Make sure to lay the waste toner container on a flat surface so that the toner does not spill.
  4. Remove the container’s cap from the container as shown in the following image, then use it to close the waste toner container opening.
    Figure : Cap placement
  5. Take a new waste toner container out of its package.
  6. Insert the new container into position and then push it to make sure that it is firmly seated in place.
    Figure : Waste toner container, insert
  7. Close the front door firmly.
    If the front door is not completely closed, the printer will not operate. Please, make sure all toner cartridges are installed properly. If any toner cartridge is installed improperly, the front door does not close.
  8. Turn the printer on.
