    Apache Log4j Update
Samsung Laser Printers - Replacing the Waste Toner Container
This document explains how to replace the waste toner container. When the life span of the waste toner container has expired, the Smart Panel program window appears on the computer, indicating the waste toner container needs to be placed. Otherwise the printer stops printing.
  • Toner particles might be released inside the printer but it does not mean the printer is damaged. If print quality problems occur, contact HP Customer Support.
  • When pulling out the waste toner container out of the printer, move the container carefully to prevent dropping the container.
  • Make sure to lay the waste toner container on a flat surface so that the toner does not spill.
Do not tilt or turn over the container.
Replacing the waste toner container
Use these steps to replace the waste toner container.
  1. Open the front door.
    Figure : Front door, open
  2. Remove the toner cartridges from the printer.
    Figure : Toner cartridges, remove
  3. Remove the waste toner container from the printer. Take the cap from the new waste toner container and place it on the old waste toner container.
      Figure : Waste toner container, remove
    1. Waste toner container
    2. Cap
    3. Recycle waste toner container
    HP recommends recycling the waste toner container, to do this go to Product Returns and Recycling.
  4. Unpack the new waste toner container, then insert it into the printer.
    Figure : Waste toner container, insert
  5. Insert the toner cartridges into the printer.
    Figure : Toner cartridges, insert
  6. Close the front door.
    Figure : Front door, close
