    Fix Windows 10 Update Issues
    Are you working from home?
HP Notebook - 14-bs007nt Product Specifications
2BT00EA
Intel® Pentium® N3710 (1.6 GHz base frequency, up to 2.56 GHz burst frequency, 2 MB cache, 4 cores)
4 GB DDR3L-1600 SDRAM (1 x 4 GB)
Video graphics
  • Intel® HD Graphics 405
  • Integrated
1 TB 5400 rpm SATA
Optical drive
DVD-Writer
35.6 cm (14") diagonal HD SVA BrightView WLED-backlit (1366 x 768)
Keyboard
Full-size island-style keyboard with numeric keypad
Pointing device
Intel® 802.11b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 Combo
2 USB 3.1 Gen 1 (Data transfer only); 1 USB 2.0; 1 HDMI; 1 VGA; 1 RJ-45; 1 headphone/microphone combo
Dimensions (W x D x H)
34 x 24 x 2.37 cm
1.9 kg
45 W AC power adapter
4-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 12 hours and 30 minutes
Video Playback Battery life
Up to 9 hours and 30 minutes
Battery type note
User-replaceable battery
HP TrueVision HD Camera with integrated digital microphone
Dual speakers
FreeDOS 1.2
