HP LaserJet Pro M14-M17 Printer Series - Wireless Printer Setup (Windows)
This document is for HP LaserJet Pro M15a, M15w, M17a, and M17w printers on a computer with Windows.
To set up an HP printer on a wireless (Wi-Fi) network, install the print driver and software from the HP website. When prompted during the installation, select Wireless as the connection type.
Step 1: Prepare for installation
Before setting up the printer on your wireless network, gather the required items, and then check the printer and computer connections.
If you need to find your network password, go to Find Your Wireless WEP, WPA, WPA2 Password (Windows).
  1. Gather the following items:
    • Network name: The network name is the SSID.
    • Network password (WEP key or WPA security passphrase)
    • A computer connected to your wireless network
    • Internet access (recommended): HP recommends broadband Internet access such as cable or DSL.
    • Your wireless-capable printer: Place your printer close to the computer during the installation.
    • USB cable: The installer prompts you when to connect the USB cable.
  2. Make sure the printer, router, and computer are all turned on, and that the computer is connected to the same wireless network to which you are connecting the printer.
  3. Disconnect any USB or Ethernet cables from the printer.
Step 2: Connect the printer to the wireless network
Use Wi-Fi Protected Setup (WPS) to connect the printer so the HP installer can find the printer during the installation. Consult your wireless router manual to confirm if it supports the WPS push button connection type.
  • If your router does not support WPS, skip to Download and install the print driver.
  • If your router supports WPS, continue with these steps.
    1. On the printer control panel, press and hold the Wireless button for three seconds.
      The Wireless light and Ready light start to blink.
    2. On your wireless router, press the WPS button.
    3. Wait up to two minutes while the printer automatically establishes a network connection with the wireless network.
After the printer connects to the network, the wireless light is on and steady.
Step 3: Download and install the print driver
Download and install the latest print driver from the HP website. If you did not connect your printer to the wireless network in the previous step, connect the printer to your computer with a USB cable to establish the wireless connection when prompted.
As an alternative method to downloading the software, you can use the installation CD.
  1. Click Download, and then click Open, Save, or Run in any windows that display to download the driver to your computer.
  2. Double-click the driver file with HP Easy Start in the name in the browser downloads bar or in the Downloads folder to start the installation.
    Figure : Example of the HP Easy Start file in the browser downloads bar
    Figure : Example of the HP Easy Start file in the Downloads folder
  3. Follow the on-screen instructions to complete the driver installation.
  4. Return to the 123.hp.com page in your web browser to complete the printer registration and activation.
Review these frequently asked questions on setting up the wireless network connection.
