HP EliteDisplay S270n Specifications
Product image
Figure : HP EliteDisplay S270n
Panel
Specification
Display panel type
In-plane switching (IPS)
Display size (diagonal)
27 inches
68.58 cm (27.0 in)
Panel active area (W x H)
596.74 x 335.66 mm (23.49 x 13.21 in)
Aspect ratio
16:9
Viewing angle (typical CR > 10)
178° horizontal
178° vertical
Brightness
350 cd/m2 (typical)
Contrast ratio (typical)
Static
1,300:1 (typical)
Dynamic Contrast Ratio (DCR)
5,000,000:1 (minimum)
10,000,000:1 (typical)
Dynamic Contrast Ratios during video playback only, depending on series of frames or time duration.
Response times
Panel native is 14.0 ms OD Gray to Gray
Can be adjusted to as low as 5.3 ms
Pixel pitch
0.1554 x 0.1554 mm
Pixels Per Inch (PPI)
163.18
Default color temperature
sRGB D65 (6500 K)
Backlight lamp life
30,000 hours minimum (to half brightness)
Color depth
10-bit (8-bit with A-FRC)
Color support
Up to 1.07 billion colors with the use of FRC technology
Color gamut
>99% sRGB
Anti-glare panel
Advanced haze
Actual performance varies.
User controls
Specification
Monitor control buttons or switches
Menu/OK
Plus ("+")
Minus ("-")
Viewing Mode
Exit
Next Input
Power
User programmable modes
10
Languages
10 (English, Spanish, German, French, Italian, Dutch, Portuguese, Japanese, Simplified Chinese, and Traditional Chinese)
On-screen Display (OSD) user controls
Brightness, Contrast, Color Control, Input Control, Image Control, PIP Control, Power Control, Menu Control, Management, Language, Information, and Exit
Signal interface/performance
Specification
Native resolution/timing
3840 x 2160 at 60 Hz
Maximum or recommended resolution
Preset graphic modes/supported resolutions
640 x 480 at 60 Hz
720 x 480 at 60 Hz
800 x 600 at 60 Hz
1024 x 768 at 60 Hz
1280 x 720 at 60 Hz
1280 x 800 at 60 Hz
1280 x 1024 at 60 Hz
1440 x 900 at 60 Hz
1600 x 900 at 60 Hz
1680 x 1050 at 60 Hz
1920 x 1080 at 60 Hz
1920 x 1200 at 60 Hz
2560 x 1440 at 60 Hz
2560 x 1600 at 60 Hz
Pixel clock
533 MHz (maximum)
Vertical scan range
24 - 60 Hz
Horizontal scan range
27 - 135 kHz
Video/other inputs/cables
Specification
Connector types
(1) HDMI 2.0 HDCP 2.2 up to 4k
(1) HDMI 1.4 HDCP 1.4
HDCP supported for DisplayPort and HDMI.
(1) DisplayPort (DP) 1.2
USB ports
(1) USB Type-C
Cables
(1) HDMI 1.8 m (5.90 ft)
(1) DisplayPort (DP) 1.8 m (5.90 ft)
(1) USB Type-C 1.8 m (5.90 ft)
Ergonomics
Specification
Color
Black head
Black Onyx (chin/base)
Chrome plated stand arm
Plug and play
Yes
Tilt range
-5° to +23° vertical
Detachable base
Yes
VESA mounting
100 mm (3.94 in)
Security lock-ready
Yes
Power
Specification
Power supply
External
Input power
100 - 240 VAC at 50/60 Hz
Maximum power
126 W
Typical power
55 W
Energy saving/standby mode
0.5 W
Power cable length
1.9 m (6.23 ft)
Physical specifications
Specification
Dimensions (W × D × H)
Unpacked with stand
61.47 x 19.05 x 49.78 cm (24.2 x 7.5 x 19.6 in)
Packaged
71.5 x 27.0 x 48.01 cm (28.15 x 10.63 x 18.9 in)
Head only
61.47 x 4.06 x 36.32 cm (24.2 x 1.6 x 14.3 in)
Packed
10.95 kg (24.14 lb)
Head only
4.85 kg (10.69 lb)
What's in the box?
Specification
Monitor and accessories
AC power cord, 1.9 m (6.23 ft)
DisplayPort (DP) cable, 1.8 m (5.90 ft)
USB Type-C cable 1.8 m (5.90 ft)
VESA mount adapter (100 x 100 mm)
Software (with CD)
HP Display Assistant
Environmental
Specification
Temperature
Operating
5° to 35° C (41° to 95° F)
Non-operating
-20° to 60° C (-4° to 140° F)
Humidity
Operating
20% to 80% non-condensing
Non-operating
5% to 95%
Altitude
Operating
0 to 5,000 m (0 to 16,400 ft)
Non-operating
0 to 12,192 m (0 to 40,000 ft)
Arsenic-free display glass
Yes
White LED backlights
Yes
Mercury-free display backlighting
Yes
Low halogen
Yes (except cables)
External power supplies, power cords, cables and peripherals are not low halogen. Service parts obtained after purchase migh not be low halogen.
Eco-label certifications & declarations
ENERGY STAR 7
EPEAT Gold (registration varies by country/region)
CEL Grade 1
Microsoft WHQL certification (Windows 7, 8, and 10)
SmartWay transport partnership (NA only)
CE
CB
MSIP
Mexico COC
ICES
ISO 9241-307
CU
cTUVus
ISC
CCC
VCCI
FCC
BSMI
WEEE
RCM
ErP
