Samsung CLP-680, CLP-415 Color Laser Printer - Replacing the Toner Cartridge
The following procedure shows how to replace the toner cartridge.
The printer uses four colors and has a different toner cartridge for each one: yellow (Y), magenta (M), cyan ©), and black (K).
  • The status LED and the toner-related message on the display indicate when each individual toner cartridges must be replaced.
  • The Samsung Printing Status program window appears on the computer telling users which toner color cartridge is empty, see Using Samsung Printer Status.
Check the type of the toner cartridge for the printer, see Available consumables.
  • Shake the toner cartridge thoroughly, it will increase the initial print quality.
  • Illustrations on this user’s guide might differ from the printer depending on its options or models. Check the printer type, see Front view.
  • To prevent damage to the toner cartridge, do not expose it to light for more than a few minutes. Cover it with a piece of paper, if necessary.
  • Do not touch the green area of the toner cartridge. Use the handle on the cartridge to avoid touching this area.
  • Do not use sharp objects such as a knife or scissors to open the toner cartridge package. They might scratch the drum of the cartridge.
  • If toner gets on the user's clothing, wipe it off with a dry cloth and wash clothing in cold water. Hot water sets toner into fabric.
  1. Open the front door.
    Figure : Front door, open
  2. Slide out the toner cartridge tray.
    Figure : Toner tray, slide out
  3. Remove the toner cartridge from the printer. To recycle the toner cartridge go to Product Returns and Recycling.
    Figure : Remove toner
  4. CLP-41xN/NW series
    1. Remove the new toner cartridge from its packaging. Make sure to recycle the packaging materials.
      Figure : Unpack toner
      Figure : Remove packaging
    2. Shake the toner cartridge five or six times from side to side.
      Figure : Shake toner
  5. CLP-68xND/DW series
  6. Insert the toner cartridge into the printer.
    Figure : Insert new toner
  7. Slide out the toner cartridge tray.
    Figure : Toner tray, slide in
  8. Close the front door.
    Figure : Front door, close
