HP t630 Thin Client Specifications
Product image
Figure : HP t630 Thin Client
HP t630 Thin Client
Operating systems
Specification
Preinstalled
HP ThinPro (Linux based)
HP Smart Zero Core (Linux based)
Microsoft Windows Embedded Standard (WES) 7E
Microsoft Windows 10 IoT Enterprise
Processors
Specification
AMD GX-420GI
2.0 GHz base frequency, up to 2.2 GHz maximum
CPU maximum frequency is based on AMD Turbo Core technology.
4 cores (x86)
16.1 W
2 MB L2 cache
Graphic Processing Unit
626 MHz
Memory
DDR4 1866
Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. Performance and clock frequency vary depending on application workload and hardware and software configurations. AMD numbering is not a measurement of higher performance.
Graphics
Specification
Supported displays
Two
Video outputs
(2) DisplayPort (DP)
(1) VGA port (optional)
The optional VGA port does not increase the number of displays supported.
Maximum screen resolution support
(2) Displays at 3840 x 2160 at 60 Hz via DP ports
(1) Display at 1920 x 1200 at 60 Hz via optional VGA port
The system should be configured with dual channel memory (two SODIMMs) for optimal display resolution performance. Dual channel memory is required to achieve maximum resolution on dual UHD displays.
Memory
Specification
Type
Dual channel DDR4 SDRAM
Data transfer rate
Up to 1866 MT/s peak transfer
Peak transfer rate
14,933 MB/s
Number of slots
(2) SODIMM
Capacities offered
4, 8, 16, and 32 GB
WES 7E is a 32-bit operating system, and only recognizes up to 3.2 GB RAM.
Reserved for graphics
256 MB, 512 MB (default), or 1 GB
The system GPU uses part of total system memory. System memory dedicated to graphics performance is not available for use by other programs.
Audio/multimedia
Specification
Audio
Audio CODECs include MP3, AAC stereo, HE AAC
Includes hardware acceleration support
(1) 3.5 mm (0.14 in) headset jack (front access)
Internal amplified speaker system for basic audio playback
Video
MPEG-4 part 2 (DivX, Xvid)
MPEG-4 part 10 (H.264), Advanced Video Coding (AVC) (H.264 encode)
MPEG-H part 2, High Efficiency Video Coding (HEVC) (H.265 decode)
WMV 7/8/9 VC-1 & ASF Demuxer
Playback of multiple 1080p videos and stretching of 1080p videos supported as long as the resolution in the operating system is set to 2560 x 1600 or lower.
Playback of multiple 2160p videos on 4K displays nor stretching the playback of 2160p video across multiple 4K displays is not supported.
Input/output ports
Specification
USB ports
(2) Hi-Speed USB 2.0 (front access)
(2) Hi-Speed USB 2.0 (rear access)
(2) SuperSpeed USB 3.0 (front access)
(1) SuperSpeed USB 3.0 (inside chassis)
Video outputs
(2) DisplayPort 1.2 digital video ports (standard)
(1) VGA analog video port (optional)
The optional VGA port does not increase the number of supported displays.
Other
(2) PS/2 keyboard/mouse ports
(1) RJ-45 Gigabit Ethernet interface
(1) Standard serial port (can be configured to produce 5 V of power)
(1) Optional serial port
(1) 3.5 mm headset jack (front access)
(1) 3.5 mm audio combo line-out/ line-in port (rear)
(1) 19 V DC power input (back)
(1) Rear I/O cover removal latch
(1) Cable lock slot
Optional rear port
(1) VGA video port
(1) Serial port
(1) Optional fiber optic NIC interface
(1) External Wi-Fi antenna connector
The port can be configured to any system or be blank.
Networking/communication
Specification
Wi-Fi (WLAN)
Intel Dual Band Wireless-AC 3168 Wi-Fi and Bluetooth 4.2 Combo 802.11ac (1x1)
Intel Dual Band Wireless-AC 8265 Wi-Fi and Bluetooth 4.2 Combo 802.11ac (1x1)
Wireless access point and Internet service required and sold separately. Availability of public wireless access points limited. The specifications for the 802.11ac WLAN are draft specifications and are not final. If the final specifications differ from the draft specifications, it might affect the ability of the notebook to communicate with other 802.11ac WLAN devices. Wireless features, performance and support may vary depending on environmental variables such as placement, settings and firmware of the access point. Contact your wireless vendor for support.
Wired LAN
Realtek RTL8111HSH-CG Gigabit Ethernet (GbE) Controller
Fibre optic networking
Allied Telesis AT-27M2/SC Fiber Fast Ethernet Network Interface
Allied Telesis AT-29M2/SC or AT-29M2/LC Fiber Gigabit Network Interface (available as option)
Supported host environments
Host environment
Protocol
Compatiblity
Microsoft Remote Desktop Services
Remote FX (RFX) and RDP
All installed operating systems
Citrix
ICA and HDX
VMware Horizon
RDP and PCoIP
Supported protocol clients
Protocol clients
Compatiblity
Citrix Receiver
Microsoft Remote Desktop client
MS WES 7E and Windows 10 IoT
VMware Horizon View client
HP Remote Graphics Software (RGS)
HP ThinPro and Smart Zero Core add-on
HP TeemTalk Terminal Emulator
MS WES 7E add-on
Free RDP
Software/security
Functionality
Application
Compatiblity
Browser support
Mozilla Firefox 36
Internet Explorer 11
Management tools
HP Device Manager
HP ThinUpdate
HP Easy Tools
MS WES 7E add-on
HP Smart Zero Client Services
Microsoft SCCM/EDM agent
Security
Trusted Platform Module (TPM)
TPM 1.2 (MS WES 7E)
TPM 2.0 (HP ThinPro/Smart Zero Core, Windows 10 IoT Enterprise, or with no operating system)
SmartCard
Logon Manager
Read-only operating system
802.1x
Microsoft Firewall
Additional components
HP Velocity
HP Easy Shell
HP Universal Print Driver
Windows Media Player 12.0
Microsoft Direct Access
Windows 10 IoT
Microsoft BranchCache
Windows 10 IoT
Microsoft AppLocker
Windows 10 IoT
Microsoft Sideloading
Windows 10 IoT
Software performance and support might vary depending on customer environment and backend.
Power
Specification
Power supply
65 W external power adapter
Worldwide auto-sensing 100 to 240 VAC at 50 to 60 Hz
Energy saving automatic power-down
Surge tolerant
Physical specifications
Specification
Dimensions (W x D x H) (vertical orientation)
Without stand
41.91 x 219.96 x 240.03 mm (1.65 x 8.66 x 9.45 in)
With stand
119.89 x 219.96 x 250.92 mm (4.72 x 8.66 x 9.88 in)
Without stand
1.45 kg (3.20 lb)
With stand
1.52 kg (3.35 lb)
The addition of optional modules increases the weight.
