HP Digital Sender Flow 8500 fn2 Document Capture Workstation, HP ScanJet Enterprise Flow N9120 fn2 Document Scanner - How to enable Network Twain Driver (HP Scan)
Issue Description
When connecting to the HP Digital Sender Flow 8500 fn2 and HP ScanJet Enterprise Flow N9120 fn2 using a Network Twain Driver (HP Scan), a scanner communication error message (shown below) might display on the computer.
Figure : Scanner communication error
Solution
To resolve the scanner communication error, you must update the network scan settings in the Embedded Web Server (EWS).
Follow the steps below to update these settings.
  1. Open a Web browser on your computer, and in the address line, type the scanner’s IP address, and then press Enter on the keyboard.
    Figure : Example of an IP address in a browser address line
  2. On the EWS Home page, sign in as an Administrator.
  3. On the top navigation menu, click the Networking tab.
  4. In the left navigation pane, click Other Settings, and then check the boxes next to WebScan and Secure WebScan to enable them.
  5. Click Apply to save these settings.
  6. Optional: On the top navigation menu, click the Security tab, click General Security, and then check the box next to Enable Remote User Auto Capture to enable the setting. Click Apply to save this setting.
Once you have updated these settings, you might need to restart the software or reconnect the network cable before the HP Scan Twain Driver will detect the device. Once the driver detects the device, you can begin scanning.
