Document ID: c05838280
Version: 1
Advisory: HP Pro Tablet 608 G1 - Recording Output Is the Same After Audio Files Are Recorded at Different Levels
Release date : 16-Nov-2017
Last updated : 17-Nov-2017
DESCRIPTION
When audio files are recorded with the Voice Recorder using different recording levels, the output volume of the files remain the same. This is exhibited when the "Enable HP Noise Reduction" option is unchecked/disabled in the DTS Audio Control Panel.
sourceInformation
SCOPE
Tablets:
  • HP Pro Tablet 608 G1
Operating Systems:
  • Microsoft Windows 10 Anniversary Update (RS1)
  • Microsoft Windows 10 Creators Update (RS2)
  • Microsoft Windows 10 Enterprise (64-bit)
  • Microsoft Windows 10 Home (32-bit)
  • Microsoft Windows 10 Home (64-bit)
  • Microsoft Windows 10 IoT (64-bit)
  • Microsoft Windows 10 Mobile
  • Microsoft Windows 10 Pro (32-bit)
  • Microsoft Windows 10 Pro (64-bit)
  • Microsoft Windows 10 TH1
RESOLUTION
To resolve this issue, follow the steps to enable the "Enable HP Noise Reduction" option in the DTS Audio Control Panel.
  1. Open the DTS Audio Control Panel.
  2. Click the DTS Audio icon in the system tray or click the Start Menu button and search for DTS Audio Control Panel.
  3. Select the Recording Experience tab.
  4. Check Enable HP Noise Reduction.
  5. Close the DTS Audio Control Panel.
Hardware platforms affected : HP Pro Tablet 608 G1
Support Communication Cross Reference ID : IA05838280
