HP Chromebook 11 G1 Education Edition Notebooks - Using the HP x360 11 EMR Pen
This document pertains to the HP x360 11 EMR Pen with Eraser and compatible Chromebook computers.
Figure : HP x360 11 EMR Pen with Eraser
About the HP x360 11 EMR Pen with Eraser
The HP x360 11 EMR Pen with Eraser is a lightweight digital stylus designed for touchscreen interaction on the HP Chromebook 11 G1 Education Edition notebooks. The pen is only compatible with touchscreens that have a digitizer. The pen uses HP Electro-Magnetic Resonance (EMR) technology to draw small amounts of energy from a sensor embedded in the panel into the internal circuitry of the pen.
The pen does not use batteries. The HP Electro-Magnetic Resonance (EMR) technology that draws energy form the panel, supplies power to the pen.
The pen is compatible with the Google Chrome operating system, and can be used to write or draw on the screen and to navigate the operating system and compatible applications.
Using the pen
You do not need to configure or pair the pen before using it with the Chromebook. It works directly out-of-the-box when used with a compatible Chromebook.
To begin using the pen, press the tip of the pen against the Chromebook’s touchscreen. The touchscreen will automatically detect the pen, and it can be used to perform the following touchscreen functions:
  • Select an item: Tap the pen once on the screen to select an item.
  • Right-click: Tap and gently press the tip on the screen to right-click an item.
  • Select multiple items: Press and hold the pen against the first item you want to select. Then, while still holding the item, press the Shift key, and select the last item. The Shift key function selects all the items between and including the first and the last item.
  • Erase items: Press and hold the eraser against the screen on the item you want to erase. Or, use the Erase tool in the Stylus tools utility to erase notes or drawings.
  • Hide or display the shelf or the taskbar: Place the tip of the pen on the bottom of the touchscreen and swipe upwards.
You cannot zoom an image in or out by placing a finger and the pen on the touchscreen and then spreading (zoom out) or pinching them together (zoom in). The touchscreen seamlessly swaps between pen-input and touch-input, but does not support the simultaneous use of pen-input and touch-input. However, to save power, the digitizer automatically deactivates if the tip has no pressure level and is out of hovering range for 1.5 seconds.
Using the stylus tools
With the Stylus tools utility, you can use the pen to take notes and screenshots, draw, or act as a laser pointer or a magnifying glass.
Take care when using the pen. The pen tips are subject to breakage. The impact from dropping the pen on the floor can break or damage the pen tip. Do not apply excessive pressure with the pen on the touchscreen. Too much pressure can cause damage to the pen tip.
To open the Stylus tools utility, tap the Stylus icon on the task bar.
Figure : Stylus tools
Menu of Stylus tools
Icon
Tool
Function
Capture region
Take a partial screenshot
Capture screen
Take a full-page screenshot
New note
Take notes and draw images on the touchscreen
Laser pointer mode
Use the pen to point to an image or region on the screen
Magnifying glass mode
Use the pen to magnify items on the screen
Help menu
Launch the Chromebook Help website that provides information on how to use a stylus with the Chromebook, and links to support forums
Settings menu
Launch a Settings menu to configure the settings for the Chromebook
Taking a partial screenshot
To take a partial screenshot on the Chromebook use the following steps:
  1. Tap the Stylus icon on the task bar to open the Stylus tools.
  2. Using the pen, tap the Capture region option.
  3. When the Use the stylus to select a region prompt is displayed, use the pen to tap and hold a point on the screen, and then drag the pen over the area you want to capture.
  4. Release the pen to finish the screenshot.
    A screenshot of the selected region is saved on the Chromebook.
Taking a full-page screenshot
To take a full-page screenshot on the Chromebook use the following steps:
  2. Using the pen, tap the Capture screen option.
    A full-page screenshot is saved on the Chromebook.
Taking notes
To use the New note option to take notes use the following steps:
  2. Using the pen, tap the New note option.
  3. Use the pen to take notes in the displayed window.
Drawing lines and sketching
To use the New note option to draw lines and sketch use the following steps:
  3. Use the menu displayed at the top of the New note screen to draw or sketch with the pen.
    Figure : The Draw icon
  4. Select the drawing tool, color, and the width of the line or stroke.
    The pen is pressure-sensitive, therefore, to increase the thickness you press a bit harder on the tip while using the pen. Apply less pressure to produce a thinner line. Some apps supported do not have the pressure sensitive feature, so it is necessary to change the width in the menu.
    Figure : Selection for drawing tool, color, and stroke width
    Menu with selections for drawing tool, color, and stroke width
  5. To erase images from the canvas, tap the Eraser icon.
    Figure : Eraser
  6. Use the pen to erase selected items or the entire page. Deactivate the eraser by tapping the eraser icon again.
Using the pen as a laser pointer
To use the pen as a laser pointer during a presentation, follow these instructions:
  2. Using the pen, select the Laser pointer option.
  3. Tap the pen to the screen. Notice the red pointer dot on the screen.
  4. To turn off the laser pointer, tap the Laser pointer option in the Stylus tools menu.
Using the pen as a magnifying glass
To enlarge something to see it up close, use the pen as a magnifying glass:
  2. Using the pen, select the Magnifying glass option.
  3. Touch the pen to the screen to magnify a point or an area on the screen.
  4. To turn off the magnifying glass, tap the Magnifying glass item in the Stylus tools menu.
Replacing the tip
If the pen-like tip of the pen becomes damaged or broken and does not work, replace it.
Your pen will appear different from the pen in the following instructions, but the procedures are accurate and applicable to the HP EMR Pen.
  1. Find the tweezers and the replacement tips.
    Figure : Tweezers and pen tips
  2. Position the circular tweezers so that the groove in the tweezers fits around the tip of the pen. Then use two fingers to firmly press the tweezers onto the tip.
    Figure : Tweezers around the tip of the pen
  3. While squeezing the tweezers, gently pull the tip from the pen.
    Figure : Removing the tip
    Removing the tip
  4. Place a replacement tip in the tip cavity, and then gently push the tip until it securely clicks into position.
    Figure : Replacing the tip
    Replacing the tip
