    Are you working from home?
    Fix Windows 10 Update Issues
HP Pavilion - 15-bc303no Product Specifications
2VZ91EA
Intel® Core™ i5-7200U (2.5 GHz base frequency, up to 3.1 GHz with Intel® Turbo Boost Technology, 3 MB cache, 2 cores)
8 GB DDR4-2133 SDRAM (1 x 8 GB)
Video graphics
  • NVIDIA® GeForce® GTX 950M (2 GB GDDR5 dedicated)
  • Discrete
1 TB 5400 rpm SATA
39.6 cm (15.6") diagonal FHD IPS anti-glare WLED-backlit (1920 x 1080)
Keyboard
Full-size island-style keyboard with numeric keypad
Pointing device
Intel® 802.11b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo
2 USB 3.1; 1 USB 2.0; 1 HDMI; 1 RJ-45; 1 headphone/microphone combo
Dimensions (W x D x H)
38.2 x 25.3 x 2.45 cm
2.2 kg
120 W AC power adapter
3-cell, 61.5 Wh Li-ion
HP Audio Switch; HP CoolSense; HP JumpStart
Pre-installed software
Netflix
1 month trial for new Microsoft® Office 365 customers
