HP Z24n G2 24-inch Display Specifications
Product image
Figure : HP Z24n G2 24-inch Display
Panel
Specification
Display panel type
24 inches IPS, LED backlight
60.96 cm (24.0 in) widescreen
Panel active area (W x H)
51.84 x 32.41 cm (20.41 x 12.76 in)
Panel hardness
3H
Panel bit depth
8-bit (6-bit with A-FRC) 16.7 Million colors
Resolution (preferred)
1920 x 1200 at 60 Hz
Aspect ratio
16:10
Viewing angle (typical CR>10)
Up to 178° horizontal (10:1 minimum contrast ratio)
Up to 178° vertical (10:1 minimum contrast ratio)
Brightness (typical)
300 cd/m2
Contrast ratio (typical)
Static
1,000:1
Dynamic Contrast Ratio (DCR)
10,000,000:1
Response times
5.8 ms, gray to gray
Default is 14.0 ms and can be adjusted to as low as 5.8 ms in the display menu. See user guide for more information.
Pixel pitch
0.270 mm
Pixel Per Inch (PPI)
94.07
Default color temperature
Neutral (6500 K)
Backlight lamp life
30,000 hours minimum (to half brightness)
Color support
Up to 16.7 million colors (with the use of FRC technology)
Color gamut (coverage)
99% (sRGB)
Anti-glare panel
Yes, haze 25%
Flicker free
Yes
Low blue light capable
Yes (user selectable in On-screen Display (OSD) menu)
Vertical scan range
24-75 Hz
Horizontal scan range
27-94 kHz
Maxium pixel clock speed
200 MHz
Actual performance varies.
User controls
Specification
Monitor control buttons or switches
Menu/OK
Minus ("-")/Down/Color Control
Plus ("+")/Up/Viewing Mode Menu
Exit/Back/Next Active Input
Power
User-assignable function buttons
10
Languages
10 (English, Spanish, German, French, Italian, Dutch, Portuguese, Japanese, Simplified Chinese, and Traditional Chinese)
On-screen Display (OSD) user controls
Brightness, Contrast, Color Control, Input Control, Image Control, Power Control, Menu Control, Management, Language, Information, and Exit
Signal interface/performance
Specification
Native resolution
The display can support up to 75 Hz refresh for some video modes. The video card of the connected PC must be capable of supporting 75 Hz.
Preset VESA graphic modes (non-interlaced)
640 x 480 at 60 Hz
720 x 400 at 70 Hz
800 x 600 at 60 Hz
1024 x 768 at 60 Hz
1280 x 720 at 60 Hz
1280 x 800 at 60 Hz
1280 x 1024 at 60 Hz
1440 x 900 at 60 Hz
1600 x 900 at 60 Hz
1680 x 1050 at 60 Hz
1920 x 1080 at 60 Hz
640 x 480 at 75 Hz
800 x 600 at 75 Hz
1024 x 768 at 75 Hz
1280 x 1024 at 75 Hz
1920 x 1200 at 75 Hz
Pixel clock speed (maximum)
200 MHz
Vertical scan range
24-75 Hz
27-94 kHz
Video/other inputs/cables
Specification
Connector types
(1) HDMI 1.4
(2) DisplayPort (DP) 1.2, (1) in and (1) out
HDCP supported for HDMI and DisplayPort (DP).
Daisy chain
Supported via DisplayPort
Up to 4 displays at FHD or WUXGA
USB ports
Downstream ports
(3) USB 3.0
(1) Side USB Type-C 3.1
Power delivery up to 10 W (5 V, 2 A)
Upstream ports
(1) Rear USB Type-C 3.1
Power delivery up to 15 W (5 V, 3 A)
Cables
(1) AC power cord 1.9 m (6.23 ft) cable
(1) DisplayPort 1.8 m (5.9 ft) cable
(1) USB 3.1 Type-C to Type-A 1.8 m (5.9 ft) cable
Transfer rate for USB 3 A and USB Type-C
5 Gb/s
Factory color calibrated
Yes
Picture-in-Picture (PiP)
Yes
Picture-by-Picture (PbyP)
Yes
Multimedia
Specification
Audio
Audio-out (connects headphone)
(1) Headphone jack
Ergonomics
Specification
Plug and play
Yes
Tilt range
-5° to +22° vertical
Swivel range
+/-45°
Pivot rotation
Yes (clockwise and counter-clockwise)
Detent at 0°
Detachable stand
Yes (ships detached)
Height adjustment
0 to 150 mm (15.0 cm)
Cable management
Integrated
Effortless routing of cables through the stand
Color
Black pearl
Monitor bezel and stand
VESA mount
100 mm (3.94 in)
Located on rear cover
Security lock-ready
Yes
Zero Bright Dot
Yes
The HP Pixel Policy allows no bright sub-pixel defects for this display.
Power
Specification
Power supply
Internal
Input power
100 - 240 VAC at 50/60 Hz
Maximum power
92 W
Maximum power is measured with monitor at maximum brightness and with USB ports loaded at 100% of maximum.
Typical power
40 W
Default power is measured with factory defaults, including factory default brightness and USB ports loaded at 25% of maximum.
Energy saving/standby mode
0.5 W
Power cable length
1.9 m (6.23 ft)
Physical specifications
Specification
Dimensions (W × D × H)
Unpacked with stand (highest setting)
53.09 x 21.34 x 50.29 cm (20.9 x 8.4 x 19.8 in)
Packaged
62.51 x 42.02 x 27.31 cm (24.61 x 16.54 x 10.75 in)
Head only
53.09 x 4.67 x 35.05 cm (20.9 x 1.84 x 13.8 in)
Base area footprint
25.91 x 21.59 cm (10.2 x 8.5 in)
Bezel measurements
Top
6.86 mm (0.27 in)
Side
6.86 mm (0.27 in)
Bottom
19.56 mm (0.77 in)
Unpacked
7.2 kg (15.87 lb)
Packaged
9.9 kg (21.83 lb)
Head only
4.4 kg (9.70 lb)
What's in the box?
Specification
Monitor and accessories
AC power cord
DisplayPort 1.2 cable
USB 3.1 Type-C to Type-A cable
Environmental
Specification
Temperature
Operating
5° to 35°C (41° to 95°F)
Non-operating
-20° to 60°C (-4° to 140°F)
Humidity
Operating
20% to 80% non-condensing
Non-operating
5% to 95% (38.7°C maximum wet-bulb)
Altitude
Operating
0 to 5,000 m (0 to 16,400 ft)
Non-operating
0 to 12,192 m (0 to 40,000 ft)
Arsenic-free display glass
Yes
Mercury-free display backlighting
Yes
Low halogen
Yes (except cables)
External power supplies, power cords, cables and peripherals are not low halogen. Service parts obtained after purchase may not be low halogen.
Eco-label certifications & declarations
WEEE
ENERGY STAR
EPEAT Gold (registration varies by country/region)
CEL Grade 2
Microsoft WHQL certification (Windows 7 and 10)
TCO certified edge
SmartWay transport partnership (North American countries/regions only)
CE
CB
MSIP
Mexico COC
ICES
ISO 9241-307
CU
cTUVus
ISC
CCC
CEL Grade 1
VCCI
FCC
BSMI
WEEE
RCM
ErP
KC/E-Standby
SEPAGS
TUV-S
TCO
TCO Edge
PSB
Vietnam MEPS
