Samsung Printers - View Toner Usage History Using Samsung Printer Diagnostics
This document introduces the flow of steps when you select the View toner usage history option in the Samsung Printer Diagnostics (SPD) application.
To use this application to view the toner usage history, select Advanced options on the main SPD screen.
Figure : Select Advanced options
Advanced options
In Advanced options, select View toner usage history.
Figure : Select View toner usage history
Select a connected printer
This screen lists the available printers. Choose the printer you want to check.
Figure : Select a printer
Toner usage history
This screen displays the toner usage history for the selected printer. Insert the service code in the dialog box. If the service code contains "admin@12", it passes. Examples include: dsdaadmin@12sda, admin@12345
Figure : Insert the service code
