HP ENVY x360 - 15-aq294cl Product Specifications
X7U57UA
Intel® Core™ i7-8550U (1.8 GHz base frequency, up to 4 GHz with Intel® Turbo Boost Technology, 8 MB cache, 4 cores)
16 GB DDR4-2133 SDRAM (2 x 8 GB)
Video graphics
  • Intel® UHD Graphics 620 (up to 8.06 GB)
  • Integrated
1 TB 7200 rpm SATA
15.6" diagonal FHD IPS WLED-backlit multitouch-enabled edge-to-edge glass (1920 x 1080)
Keyboard
Pointing device
Intel® 802.11b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo
1 USB 3.1 Type-C™ Gen 1 (Data up to 5 Gb/s); 2 USB 3.1 Gen 1 (1 HP Sleep and Charge); 1 HDMI; 1 headphone/microphone combo
Dimensions (W x D x H)
38 x 25 x 1.88 cm
2.17 kg
45 W AC power adapter
4-cell, 55.67 Wh Li-ion
Bang & Olufsen, dual speakers
HP 3D DriveGuard; HP Audio Switch; HP CoolSense; HP ePrint; HP JumpStart; HP Recovery Manager; HP Support Assistant
Pre-installed software
Netflix
