Document ID: c05809577
Version: 1
HP Oct. 2017 BIOS Refresh
Release date : 20-Oct-2017
Last updated : 20-Oct-2017
DETAILS OF CHANGE
Common changes for all platforms:
  • Fixed issue where Ctrl + Alt + Delete can bypass DirveLock Password.
  • Fixed issue where BitLocker could not be enabled while FastBoot is enabled.
  • Fixed issue where Sandisk SDSSDHII-480G-G25 can't be recognized in legacy mode.
  • Add feature that Power-on password is bypassed only on the initial Wake-on-LAN.
  • Fixed issue where SMC blob in FAT32 HDD is not working when USB Storage Boot is disabled.
  • Add Wake on LAN option "Boot to normal boot order" in F10 setup menu.
  • Add TPM1.2 to 2.0 Upgrade PPI to "TPM Activation Policy".
  • Fixed issue where USB Type C FW update failed intermittently.
  • Fixed issue where X2APIC unexpected disabled in Intel platform.
  • Add enable/disable individual HDD in F10 setup menu separately in Intel platform.
  • Add a feature to enable battery shipmode via F10 setup menu and BCU.
  • Update Intel MCU of SkyLake U/Y to 0xBC.
  • Update audio verb table to fix unexpected beep sound behavior in F10 setup menu.
  • Improved security of UEFI code and variables. HP strongly recommends promptly transitioning to these updated BIOS versions which supersede all previous releases.
Due to the security changes in this release, attempts to install older BIOS versions will require the user to be physically present to accept the older version.
HP EliteBook 850/840/820 G3, ZBook 15u G3 Mobile Workstation System BIOS has the following enhancements added:
  • Add an option to control Active Management(AMT) on/off via F10 setup menu and BCU.
  • Add Intel Pleasant Star SSD support.
HP ZBook Studio G3 Mobile Workstation System BIOS and HP ZBook 17/15 G3 Mobile Workstation System BIOS has the following enhancements added:
  • Add enable/disable external ports in F10 setup menu separately.
  • Add a feature that can disable the discrete video card for ZBook Studio.
  • Fixed issue where some of external USB ODD Drives are not detected.
  • Fixed issue where sometimes USB-A and Audio jack lost function on trump after restart the unit.
  • Add Nvidia Graphics Card M1200/2200 support on ZBook 17/15 G3 Mobile Workstation.
  • Fixed issue where HP Performance Advisor does not have sensors options.
  • Update Realtek 8153 PXE to v2.10 and UEFI driver to v2.020.
HP EliteBook Folio G1 System BIOS has the following enhancements added:
  • Fixed issue where power LED still keep bright after put unit into Connect Standby.
  • Fixed issue where intermittently system hang at idle state.
HP Elite x2 1012 G1 System BIOS has the following enhancements added:
  • Fixed issue where rotation function is not workable when resume from S3/S4 after changing the Clamshell mode as Tablet mode.
  • Fixed issue where touchpad still can working when open the lid to 201°-345°.
HP EliteBook 1030 G1 System BIOS has the following enhancements added:
HP EliteBook Folio 1040 G3 System BIOS has the following enhancements added:
HP ProBook 650/640 G2 System BIOS has the following enhancements added:
  • Fixed issue where two "Docking USB Ports" display in F10.
  • Fixed issue where can't boot to NTFS bootable USB Key in UEFI mode.
HP ProBook 470/450/440/430 G3 System BIOS has the following enhancements added:
COMPONENT VERSION
  • HP EliteBook 850/840/820 G3, ZBook 15u G3 Mobile Workstation System BIOS 01.18
  • HP ZBook 17/15 G3 Mobile Workstation System BIOS 01.17
  • HP ZBook Studio G3 Mobile Workstation System BIOS 01.19
  • HP EliteBook Folio G1 System BIOS 01.16
  • HP Elite x2 1012 G1 System BIOS 01.24
  • HP EliteBook 1030 G1 System BIOS 01.10
  • HP EliteBook Folio 1040 G3 System BIOS 01.16
  • HP ProBook 650/640 G2 System BIOS 01.11
  • HP ProBook 470/450/440/430 G3 System BIOS 01.19
  • HP ProBook 11 EE G2 System BIOS 01.09
  • HP EliteBook 745/755 G3 System BIOS 01.20
  • HP ProBook 645/655 G2 System BIOS 01.10
  • HP ProBook 455 G3 System BIOS 01.17
REASON FOR CHANGE
Regular quarterly release.
IMPACT OF CHANGE
Components affected:
System BIOS
DATE OF CHANGE
Effective date : 23-Oct-2017
Hardware platforms affected : HP EliteBook 1030 G1 Notebook PC, HP EliteBook 1040 G3 Notebook PC, HP EliteBook 745 G3 Notebook PC, HP EliteBook 755 G3 Notebook PC, HP EliteBook 820 G3 Notebook PC, HP EliteBook 840 G3 Notebook PC, HP EliteBook 850 G3 Notebook PC, HP ProBook 11 EE G2, HP ProBook 430 G3 Notebook PC, HP ProBook 440 G3 Notebook PC, HP ProBook 450 G3 Notebook PC, HP ProBook 455 G3 Notebook PC, HP ProBook 470 G3 Notebook PC, HP ProBook 640 G2 Notebook PC, HP ProBook 645 G2 Notebook PC, HP ProBook 650 G2 Notebook PC, HP ProBook 655 G2 Notebook PC, HP ZBook 15 G3 Mobile Workstation, HP ZBook 15u G3 Mobile Workstation, HP ZBook 17 G3 Mobile Workstation, HP ZBook Studio G3 Mobile Workstation
