HP PageWide Pro 700 series - Margin shows on the top and bottom of copy output from the ADF
Issue Description
If a user places a letter-size document in the Automatic Document Feeder (ADF) in landscape orientation (short-edge leading) and chooses to resize the output to A4 (choosing a paper tray loaded with A4 media), the printer will shrink the image leaving a margin at the top and the bottom of the printed output.
Workaround/Solution
The current workaround is to load the letter-size document in portrait orientation (long-edge leading) into the Automatic Document Feeder (ADF). As an alternative, the letter-size document may be placed on the glass in landscape orientation.
HP plans to address this behavior in a future firmware release.
Product Numbers
The following products can exhibit the symptoms listed above:
Product models:
  • HP PageWide Pro MFP 772dw
  • HP PageWide Pro MFP 772dn
  • HP PageWide Pro MFP 777zs
  • HP PageWide Pro Managed MFP 77740z
  • HP PageWide Pro Managed MFP 77750z
  • HP PageWide Pro Managed MFP 77760z
  • HP PageWide Pro Managed MFP 77740zs
  • HP PageWide Pro Managed MFP 77750zs
  • HP PageWide Pro Managed MFP 77760zs
Product numbers:
  • W1B31
  • Y3Z54
  • Y3Z59
  • W1B39
  • W1B37
  • W1B38
  • W1B40
  • W1B41
  • W1B42
Serial Numbers
This issue is not constrained to a specific range of serial numbers.
