Product Specifications for the HP Envy Photo 7822 All-in-One Printer (Y0G42D)
Product naming
Model name
HP ENVY Photo 7822 All-in-One Printer
Y0G42D
Connectivity
Ports
1 USB 2.0 client and 1 USB host (for thumbdrive); 1 Wi-Fi 802.11b/g/n; 1 Ethernet; 1 RJ-11 (Fax), dual band wifi 2.4/5Ghz, BLE,SD card slot
Wireless capability
Yes, built-in Ethernet, dual band Wi-Fi 802.11b/g/n
Copy
Color copy capability
Yes
Maximum number of copies
Up to 50 copies
Copy speed, black (draft, A4)
Up to 21 cpm
Copy resolution
300 x 300 dpi
Environmental
Acoustic power emissions
6.2 B(A) (print mono, simplex, normal mode at 9ppm)
Acoustic pressure emissions
57 dB(A) (Print mono, simplex , normal mode A4 at 10ppm)
Operating humidity range
20 to 80% RH
Non-Operating humidity range
10 to 90% RH (non condensing)
Recommended operating temperature range (Celsius)
15 to 32ºC
Recommended operating temperature range (Fahrenheit)
59 to 89.6ºF
Storage temperature range (Celsius)
-40 to 60ºC
Storage temperature range (Fahrenheit)
-40 to 140ºF
Fax
Fax available
Yes, color
Fax features
Handset not available
Fax Resolution Black (best)
Up to 300 x 311 dpi
Fax memory
Up to 100 pages in black and white
Telephone handset supported
No
Fax telephone mode supported
Yes
Fax Speed Dials, Maximum Number
Up to 120 numbers
Memory
Memory
256 MB DDR3
Memory card compatibility
Secure Digital
Mobile printing capability
Mobile printing services
HP ePrint; Apple AirPrint; Mopria-certified; Wireless Direct Printing
Networking
Network protocols, supported
IPv4, IPv6, Bonjour, Custom Raw Port/Port9100, mDNS, Embedded Web Server, Wireless Network Supported,SLP, WS-Print, Wireless b/g/n, WEP/WPA (AES), SNMP, Internet Printing Protocol, Bluetooth LE
Paper handling
Input capacity
Up to 125 sheets
Standard input capacity (cards)
Up to 40 cards
Standard input capacity (envelopes)
Up to 5
Standard input capacity (transparencies)
Up to 40 sheets
Standard input capacity (secondary tray)
Up to 15 sheets
Output capacity
Up to 25 sheets
Media sizes supported (metric)
A4; A5; B5; DL; C6; A6
Media sizes supported (U.S. standard)
Letter, Legal, 4 x 5 in, 4 x 6 in, 5 x 7 in, 8 x 10 in, No. 10 envelopes
Media sizes, custom (metric)
97.79 x 215 to 127 x 355 mm
Media sizes, custom (U.S. standard)
3.85 x 8.46 to 5 x 13.97 in
Media types
Plain Paper; HP Photo Papers; HP Matte Brochure or Professional Paper; HP Matte Presentation Paper; HP Glossy Brochure or Professional Paper; Other Photo Inkjet Papers; Other Matte Inkjet Papers; Other Glossy Inkjet Papers, Plain Paper, Light/Recycled
Media weight supported (metric)
Tray 1: A4: 75 to 90 g/m²; HP envelopes: 75 to 90 g/m²; HP Photo Paper: up to 250 g/m²; HP 10 x 15 cm photo paper: up to 250 g/m²
Media weight supported (U.S. standard)
Tray 1: A4: 21.42 to 25.71 lb; HP envelopes: 21.42 to 25.71 lb; HP Photo Paper: up to 71.42 lb; HP 3.9 x 5.9 in photo paper: up to 71.42 lb
Borderless printing
Yes (up to 8.5 x 11 in, 216 x 297 mm)
Paper handling - ADF
Automatic document feeder capacity
Standard, 35 sheets
Physical dimensions
Maximum dimensions (W x D x H, metric)
453.5 x 502.8 x 193.2 mm
Maximum dimensions (W x D x H, U.S. standard)
17.85 x 19.79 x 7.60 in
Weight (metric)
7.60 kg
Weight (U.S. standard)
16.75 lb
Power
Energy savings feature technology
HP Auto-Off Technology
Built-in Universal Power Supply
Power supply
Input voltage: 100 to 240 VAC (+/- 10%), 50/60 Hz (+/- 3 Hz)
Power consumption
13.95 watts (printing), 3.60 watts (ready), 0.93 watts (sleep), 0.20 watts (off)
Print cartridges
Number of print cartridges
2:1 black, 1 Tri-color (cyan, magenta, yellow)
SureSupply note
HP SureSupply alerts you when you should replace a print cartridge and helps you purchase locally or via the Internet. For more information, visit http://www.hp.com/learn/suresupply. Only available with original HP supplies; Internet access required.
Printing specifications
Print technology
HP Thermal Inkjet
Duplex printing
Automatic
Print speed black (ISO)
Up to 15 ppm
Print speed color (ISO)
Up to 10 ppm
Print resolution (best)
Up to 1200 x 1200 rendered dpi (when printing from a computer)
Maximum print area (metric)
209.9 x 349.6 mm
8.26 x 13.6 in
Monthly duty cycle
Up to 1000 pages
Print languages
HP PCL 3 GUI
Regulatory specifications
Regulatory model number
SDGOB-1612
Scan
Scan technology
Contact Image Sensor (CIS)
Scan resolution, hardware
Up to 1200 dpi
Levels of grayscale
256
Scanning options (ADF)
Single-Sided
Maximum flatbed scan size (metric)
216 x 297 mm
Maximum flatbed scan size (U.S. standard)
8.5 x 11.69 in
Maximum ADF scan size (metric)
216 x 356 mm
Maximum ADF scan size (U.S. standard)
8.5 x 14.01 in
Twain version
Version 2.1
System requirements
Minimum system requirements for Windows
Microsoft Windows 10, 8, 7: 1 GHz 32-bit (x86) or 64-bit (x64) processor, 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Microsoft Internet Explorer. Windows Vista: 800 MHz 32-bit (x86) processor, 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Microsoft Internet Explorer 8. Windows XP SP3 or higher (32-bit only): any Intel Pentium II, Celeron or 233 MHz compatible processor, 850 MB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Microsoft Internet Explorer 8. Windows Vista x64 has been removed from support on the CD & Web packs. Windows Server support is provided via the command line installer and supports Win Server 2008 R2 and higher.
Recommended system requirements for Windows
Windows 10, 8, 7: 1 GHz 32-bit (x86) or 64-bit (x64) processor, 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Microsoft Internet Explorer. Windows Vista (32-bit only): 800 MHz 32-bit (x86) processor, 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Microsoft Internet Explorer 8.Windows XP SP3 or higher (32-bit only): any Intel Pentium II, Celeron or 233 MHz compatible processor, 850 MB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer 8.
Minimum System Requirements for Macintosh
OS X v10.10 (Yosemite), v10.11 (El Capitan) , v10.12 (Sierra), 1 GB HD, Internet
Recommended Macintosh system requirements
Mac OS X (Lion), (Mountain Lion), (Mavericks); Intel Core Processor; 1 GB HD; CD-ROM/DVD or Internet; USB
Compatible Network Operating Systems
Windows 10 (32-bit and 64-bit), Windows 8 (32-bit and 64-bit), Windows 7 (32-bit and 64-bit), Windows Vista (32-bit and 64-bit), Windows XP (32-bit) (Professional and Home Editions); Mac OS X v 10.8, v 10.9 or v 10.10; Linux (For more information, see http://hplipopensource.com/hplip-web/index.html).
Operating system (supported note)
One-year limited hardware warranty
