    Are you working from home?
    Fix Windows 10 Update Issues
HP Notebook - 15-bw035ur Product Specifications
2BT55EA
AMD Dual-Core A6-9220 APU (2.5 GHz base frequency, up to 2.9 GHz burst frequency, 1 MB cache)
4 GB DDR4-1866 SDRAM (1 x 4 GB)
Video graphics
AMD Radeon™ 520 Graphics (2 GB DDR3 dedicated)
128 GB M.2 SSD
39.6 cm (15.6") diagonal FHD SVA anti-glare WLED-backlit (1920 x 1080)
Keyboard
Full-size island-style keyboard with numeric keypad
Pointing device
802.11b/g/n (1x1) Wi-Fi® and Bluetooth® 4.0 combo
2 USB 3.1 Gen 1 (Data transfer only); 1 USB 2.0; 1 HDMI; 1 RJ-45; 1 headphone/microphone combo
Dimensions (W x D x H)
38 x 25.38 x 2.38 cm
1.91 kg
65 W AC power adapter
4-cell, 41 Wh Li-ion
Battery type note
User-replaceable battery
HP Webcam with integrated digital microphone
Dual speakers
HP Audio Switch; HP CoolSense; HP JumpStart; HP Sure Connect
1 month trial for new Microsoft® Office 365 customers
