    Fix Windows 10 Update Issues
    Are you working from home?
HP ENVY - 13-ad014ur Product Specifications
1WS60EA
Intel® Core™ i5-7200U (2.5 GHz base frequency, up to 3.1 GHz with Intel® Turbo Boost Technology, 3 MB cache, 2 cores)
8 GB LPDDR3-1866 SDRAM (onboard)
Video graphics
  • NVIDIA® GeForce® MX150 (2 GB GDDR5 dedicated)
  • Discrete
512 GB PCIe® NVMe™ M.2 SSD
33.8 cm (13.3") diagonal FHD IPS BrightView micro-edge WLED-backlit edge-to-edge glass (1920 x 1080)
Keyboard
Pointing device
HP SecurePad with multi-touch gesture support
Intel® 802.11b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo
1 microSD media card reader
2 USB 3.1 Type-C™ Gen 1 (Data Transfer up to 5 Gb/s, Power Delivery, DP1.2, HP Sleep and Charge); 2 USB 3.1 Gen 1 (1 HP Sleep and Charge); 1 headphone/microphone combo
Dimensions (W x D x H)
30.54 x 21.56 x 1.39 cm
1.38 kg
65 W AC power adapter
3-cell, 51 Wh Li-ion
HP Wide Vision HD Camera with dual array digital microphone
Bang & Olufsen; HP Audio Boost; Quad speakers
HP Audio Switch; HP CoolSense; HP JumpStart; HP Sure Connect
1 month trial for new Microsoft® Office 365 customers
