    Fix Windows 10 Update Issues
HP ElitePOS 10.1-inch Display Specifications
Product image
Figure : HP ElitePOS 10.1-inch Display
General specifications
Specification
Display panel type
IPS with LED backlight
26.65 cm (10.1 in)
Input connectors
USB-C (upstream)
5 Gbits/sec, 5 V/3 A, and Alternate mode
Panel active area (H x V)
216.96 x 135.60 mm (8.54 in x 5.34 in)
Aspect ratio
16:10
Viewing angle (typical CR>10)
170° horizontal
170° vertical
Brightness (typical CR>10)
500 cd/m2
Static contrast ratio (typical)
800:1
Response times
25 ms
Pixel pitch (H x V)
0.1695 x 0.1695 mm
Pixels Per Inch (PPI)
149
Default color temperature
Neutral (6500 K)
Backlight lamp life
50,000 hours minimum (to half brightness)
Color support
Up to 16.1 million colors
Color gamut (typical)
45%
Anti-glare panel
Yes
Color
Ebony Black or Ceramic White
Compatible system
Specification
Compatibility
HP ElitePOS G1 Retail System
All the HP Retail system models are not available in all countries/regions.
Also compatible with some other HP products via USB-C flex port USB-C DisplayPorts Alt-mode technology.
User controls
Specification
Monitor control buttons or switches
Menu/OK
Plus ("+")/Up/Color Control
Minus ("- ")/Down/Information
Exit/Back/Brightness
Power
User programmable modes
10
Languages
10 (English, Spanish, German, French, Italian, Dutch, Portuguese, Japanese, Simplified Chinese, and Traditional Chinese)
On-screen Display (OSD) user controls
Brightness, Contrast, Color Control, Input Control, Image Control, Power Control, Menu Control, Management, Language, Information, and Exit
Signal interface/performance
Specification
Native resolution
1280 x 800 at 60 Hz
Maximum resolution
1280 x 800 at 60 Hz
Preset graphic modes/supported resolutions
640 x 480 at 60 Hz
800 x 600 at 60 Hz
1024 x 768 at 60 Hz
1280 x 720 at 60 Hz
1280 x 800 at 60 Hz
Pixel clock
110 MHz (maximum)
Vertical frequency
50 - 60 Hz
Horizontal frequency
30 - 54 kHz
Ergonomics
Specification
Plug and play
Yes
Tilt range
15° to +90°
Color of monitor bezel and stand
Black
VESA mounting
Yes
Power
Specification
Power source
USB-C
5 V/3 A, 15 W
Maximum power
15 W
Typical power
12 W
Energy saving/standby mode
0.5 W
Physical specifications
Specification
Dimensions (W × D × H)
Unpacked without stand
24.61 x 15.42 x 3.50 cm (9.69 x 6.07 x 1.38 in)
Packaged
30.61 x 11.0 x 23.19 cm (12.05 x 4.33 x 9.13 in)
Display head only
24.61 x 15.42 x 1.50 cm (9.69 x 6.07 x 0.59 in)
Base area footprint
11.99 x 18.0 cm (4.72 x 7.09 in)
Unpacked with stand
1.49 kg (3.28 lb)
Packaged (single pack)
1.93 kg (4.25 lb)
Packaged (bulk pack)
10.67 kg (23.52 lb)
What's in the box?
Specification
Contents
Captive USB Type-C cable (1.8 m)
Stand
Environmental
Specification
Temperature
Operating
5° to 35°C (41° to 95°F)
Non-operating
-20° to 60°C (-4° to 140°F)
Humidity
Operating
20% to 80% non-condensing
Non-operating
5% to 95%
Altitude
Operating
0 to 5,000 m (0 to 16,400 ft)
Non-operating
0 to 12,192 m (0 to 40,000 ft)
Arsenic-free display glass
Yes
Mercury-free display backlighting
Yes
Low halogen
Yes
Agency approvals and certifications
ENERGY STAR 7.0
EPEAT Gold (registration varies by country/region)
Microsoft WHQL certification (Windows 7, 8, and 10)
TCO certified
CE
CB
MSIP
Mexico CoC
ICES
ISO 9241-307
EAC
cTUVus
CCC
TUV-Barunt
VCCI
FCC
RCM
BSMI
WEEE
Ukraine
Morocco
