    Are you working from home?
    Fix Windows 10 Update Issues
HP Stream - 14-ax001nb Product Specifications
Y3W83EA
Intel® Celeron® N3060 (1.6 GHz, up to 2.48 GHz, 2 MB cache, 2 cores)
4 GB DDR3L-1600 SDRAM (1 x 4 GB)
Video graphics
Intel® HD Graphics 400
32 GB eMMC
35.6 cm (14") diagonal HD SVA BrightView WLED-backlit (1366 x 768)
Keyboard
Full-size island-style keyboard
Pointing device
Intel® 802.11a/b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo (Miracast compatible)
1 HDMI; 1 headphone/microphone combo; 1 USB 2.0; 2 USB 3.1
Dimensions (W x D x H)
33.7 x 22.6 x 1.79 cm
1.44 kg
45 W AC power adapter
3-cell, 41 Wh Li-ion
HP Webcam with integrated digital microphone
DTS Studio Sound™; Dual speakers
HP Audio Switch; HP JumpStart
Pre-installed software
Netflix
1 month trial for new Microsoft® Office 365 customers
