    Are you working from home?
    Fix Windows 10 Update Issues
HP Notebook - 17-bs022nm Product Specifications
2WF55EA
Intel® Core™ i5-7200U (2.5 GHz base frequency, up to 3.1 GHz with Intel® Turbo Boost Technology, 3 MB cache, 2 cores)
8 GB DDR4-2133 SDRAM (1 x 8 GB)
Video graphics
  • AMD Radeon™ 530 Graphics (2 GB DDR3 dedicated)
  • Discrete
256 GB M.2 SSD
Optical drive
DVD-Writer
43.9 cm (17.3") diagonal FHD IPS anti-glare WLED-backlit (1920 x 1080)
Keyboard
Full-size island-style keyboard with numeric keypad
Pointing device
Intel® 802.11b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 Combo
2 USB 3.1 Gen 1 (Data transfer only); 1 USB 2.0; 1 HDMI; 1 RJ-45; 1 headphone/microphone combo
Dimensions (W x D x H)
41.5 x 27.8 x 2.46 cm
2.5 kg
65 W AC power adapter
4-cell, 41 Wh Li-ion
Battery type note
User-replaceable battery
HP TrueVision HD Camera with integrated digital microphone
Dual speakers
FreeDOS 1.2
