HP Z8 G4 Workstation
Intel Xeon Platinum 8180
2.5 GHz
38.50 MB cache and 28 cores
Up to 3.8 GHz with Intel Turbo Boost Technology
Supports DDR4 memory up to 2666 MT/s data rate
205 W
Supports Intel vPro technology
Intel Xeon Platinum 8160
2.1 GHz
33 MB cache and 24 cores
Up to 3.7 GHz with Intel Turbo Boost Technology
150 W
Intel Xeon Gold 6154
3.0 GHz
24.75 MB cache and 18 cores
200 W
Intel Xeon Gold 6152
2.1 GHz
30.25 MB cache and 22 cores
140 W
Intel Xeon Gold 6148
2.4 GHz
27.50 MB cache and 20 cores
150 W
Intel Xeon Gold 6142
2.6 GHz
22 MB cache and 16 cores
150 W
Intel Xeon Gold 6140
2.3 GHz
140 W
Intel Xeon Gold 6136
3.0 GHz
24.75 MB cache and 12 cores
150 W
Intel Xeon Gold 6134
3.2 GHz
24.75 MB cache and 8 cores
130 W
Intel Xeon Gold 6132
2.6 GHz
19.25 MB cache and 14 cores
140 W
Intel Xeon Gold 6130
2.1 GHz
125 W
Intel Xeon Gold 6128
3.4 GHz
19.25 MB cache and 6 cores
115 W
Intel Xeon Gold 5120
2.2 GHz
Up to 3.2 GHz with Intel Turbo Boost Technology
Supports DDR4 memory up to 2400 MT/s data rate
105 W
Intel Xeon Gold 5118
2.3 GHz
16.5 MB cache and 12 cores
105 W
Intel Xeon Gold 5122
3.6 GHz
16.5 MB cache and 4 cores
105 W
Intel Xeon Silver 4116
2.1 GHz
Up to 3.0 GHz with Intel Turbo Boost Technology
85 W
Intel Xeon Silver 4114
2.2 GHz
13.75 MB cache and 10 cores
85 W
Intel Xeon Silver 4112
2.6 GHz
8.25 MB cache and 4 cores
85 W
Intel Xeon Silver 4108
1.8 GHz
11 MB cache and 8 cores
85 W
Intel Xeon Bronze 3106
1.7 GHz
Supports DDR4 memory up to 2133 MT/s data rate
85 W
Intel Xeon Bronze 3104
1.7 GHz
8.25 MB cache and 6 cores
85 W
Intel C622
note:Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. 64-bit computing system required. Performance and clock frequency vary depending on application workload and hardware and software configurations. Intel numbering is not a measurement of higher performance.When ordering two processors, the second processor must be the same as the first.
Feature
Entry 3D
NVIDIA Quadro P400 2GB Graphics
NVIDIA Quadro P600 2GB Graphics
AMD FirePro W2100 2GB Graphics
note: |
Mid-range 3D
NVIDIA Quadro P1000 4GB Graphics
NVIDIA Quadro P2000 5GB Graphics
AMD Radeon Pro WX 3100 4GB Graphics
AMD Radeon Pro WX 4100 4GB Graphics
Supports AMD Enduro Technology
Microsoft DirectX 12 (Shader Model 5.0) and OpenGL 4.3 capable
note: |
High End 3D
Radeon Pro WX7100 8GB Graphics
NVIDIA Quadro P4000 8GB Graphics
NVIDIA Quadro P5000 16GB Graphics
NVIDIA Quadro P6000 24GB Graphics
note: |
Graphics cable adapters
HP Mini DisplayPort to DisplayPort adapter
HP Mini DisplayPort to DisplayPort adapter (2-pack)
HP Mini DisplayPort to DisplayPort adapter (4-pack)
HP Mini DisplayPort to DisplayPort adapter (6-pack)
HP DisplayPort to Dual Link DVI Adapter
HP DisplayPort to DVI-D Adapter
HP DisplayPort to DVI-D Adapter (2-pack)
HP DisplayPort to DVI-D Adapter (4-pack)
HP DisplayPort to DVI-D Adapter (6-pack)
HP DisplayPort to VGA Adapter
NVIDIA SLI Graphics connector
Feature
Displays
HP Z Display Z22n G2
HP Z Display Z23n G2
HP Z Display Z24i G2
HP Z Display Z24n G2
HP Z Display Z24nf G2
HP Z Display Z27n G2
HP Z Display Z27s (4K display)
note: |
Feature
Serial Attached SCSI (SAS) Hard drive
HP 300GB 15K SAS SFF Hard Drive (controller add-in card required)
SATA Hard Disk Drive (HDD)
HP 500GB SATA 6Gb/s 7200 Hard Drive
HP 500GB 7200rpm SATA SFF SED Hard Drive
HP 1TB SATA 6Gb/s 7200 Hard Drive
HP 1TB Enterprise SATA 7200 HDD
HP 2TB SATA 6Gb/s 7200 Hard Drive
HP 4TB SATA 7200 Hard Drive
note: |
SATA Solid State Drives (SSD)
HP 256GB SATA SSD
HP 512GB SATA SSD
HP 1TB SATA SSD
HP 2TB SATA SSD
HP 256GB SATA SED Opal2 Solid State Drive
HP 512GB SATA SED Opal2 Solid State Drive
HP Enterprise Class 240GB SATA SSD
HP Enterprise Class 480GB SATA SSD
PCIe Solid State Drives (SSD)
HP Z Turbo Drive 256GB MLC (Z8G4) SSD Module
HP Z Turbo Drive 256GB MLC (Z8G4) SSD Kit
HP Z Turbo Drive 512GB MLC (Z8G4) SSD Module
HP Z Turbo Drive 512GB MLC (Z8G4) SSD Kit
HP Z Turbo Drive 1TB MLC (Z8G4) SSD Module
HP Z Turbo Drive 1TB MLC (Z8G4) SSD Kit
HP Z Turbo Drive 256GB TLC (Z8G4) SSD Module
HP Z Turbo Drive 256GB TLC (Z8G4) SSD Kit
HP Z Turbo Drive 512GB TLC (Z8G4) SSD Module
HP Z Turbo Drive 512GB TLC (Z8G4) SSD Kit
HP Z Turbo Drive 1TB TLC (Z8G4) SSD Module
HP Z Turbo Drive 1TB TLC (Z8G4) SSD Kit
HP Z Turbo Drive 256GB SED (Z8G4) SSD Module
HP Z Turbo Drive 256GB SED (Z8G4) SSD Kit
HP Z Turbo Drive 512GB SED (Z8G4) SSD Module
HP Z Turbo Drive 512GB SED (Z8G4) SSD Kit
HP Z Turbo Drive Quad Pro
HP Z Turbo Drive Quad Pro 2x256GB PCIe SSD
HP Z Turbo Drive Quad Pro 2x512GB PCIe SSD
HP Z Turbo Drive Quad Pro 2x1TB PCIe SSD
note: HP Z Turbo Drive Quad Pro 256GB SSD module
HP Z Turbo Drive Quad Pro 512GB SSD module
HP Z Turbo Drive Quad Pro 1TB SSD module
note: |
On-board RAID support
SATA RAID 0 Striped array configuration
SATA RAID 1 Mirrored array configuration
SATA RAID 10 Striped/mirrored array configuration
SATA RAID 5 Parity array configuration
Hard drive controllers
MicroSemi 2100-4i4e SAS Controller (Smart Host Bus Adapter)
HP Slim tray optical drives
HP 9.5mm Slim Blu Ray Disc Writer
HP 9.5mm Slim DVD ROM
HP 9.5mm Slim DVD Writer
note: |
HP SD Card reader
HP SD 4 Card reader
note:For solid state drives or hard drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 30 GB is reserved for system recovery software.
Specification
DDR4-2666 ECC registered DIMMs
HP 8GB (8 GB x 1) DDR4-2666 ECC Reg RAM
HP 16GB (16 GB x 1) DDR4-2666 ECC Reg RAM
HP 32GB (32 GB x 1) DDR4-2666 ECC Reg RAM
HP 64GB (64 GB x 1) DDR4-2666 ECC Reg RAM
Maximum
Supports up to 768 GB using Registered DIMMs
caution:The system does not work if Load Reduced (LR) DIMMs are intermixed with Registered DIMMs.The Z8 G4 is designed to work ONLY with DDR4 memory. The system does not work with DDR3 memory.
note:DIMMs should be equally distributed across all six memory channels for optimal performance.Each processor supports up to six channels of DDR4 memory. To realize full performance at least one DIMM must be inserted into each channel. The CPUs determine the speed at which the memory is clocked. If a 2400 MT/s capable CPU is used in the system, the maximum speed the memory runs at is 2400 MT/s, regardless of the specified speed of the memory.
Input/output ports
Front I/O (base)
(4) USB 3.1 Gen 1 Type-A connector (left most connector has charging capability)
(1) Combo headset
(1) Optional media card reader
Front I/O (premium)
(2) USB 3.1 Gen 1 Type-A connector (left most connector has charging capability)
(2)
USB 3.1 Gen 2 Type-C connector
(1) Combo headset
Internal I/O
(1) PCIe Gen 3 x8 (internal slot always available for CPU)
(1) PCIe Gen 3 x8 (internal slot available when 2nd CPU is installed)
(2) USB 2.0 ports available with a single 2x5 header
(1) USB 2.0 port available with a 1x6 header
(1) USB 3.1 Gen 1 and (1) USB 2.0 port available with a 2x6 header
Rear I/O
(6) USB 3.1 Gen 1 (aka USB 3.0)
(1) Serial
(1) PS/2 Keyboard
(1) PS/2 Mouse
(2) RJ-45 to integrated Gigabit LAN
(1)
Audio line-in (can be retasked as microphone)
(1) Audio line-out
Slot 1
PCIe Gen 3 x4 (transforms to PCIe Gen 3 x8 when 2nd CPU is installed)
Slot 2
PCIe Gen 3 x16
Slot 3
PCIe Gen 3 x16 (available ONLY when 2nd processor is installed)
Slot 4
PCIe Gen 3 x16
Slot 5
PCIe Gen 3 x4
Slot 6
Slot 7
PCIe Gen 3 x4
note: |
Expansion bays
(4) Internal 8.89 cm (3.5 in) bays
(2) External 13.33 cm (5.25 in) bays
(1) 9.5 mm (0.37 in) slim optical disk drive bay
Feature
Audio
Integrated Realtek HD ALC221 Audio
Feature
Keyboards and mouse
HP Wireless Business Slim Keyboard and Mouse
HP PS/2 Slim Business Keyboard
HP USB Slim Business Keyboard
HP USB Premium Keyboard
HP USB SmartCard CCID Keyboard
3Dconnexion CadMouse
HP Optical USB Mouse
HP PS/2 Mouse
HP USB 1000dpi Laser Mouse
HP USB Hardened Mouse
Other hardware
HP Internal USB Port Kit (single USB 2.0 Type-A connector)
HP eSATA PCI Cable Kit (hot plug/hot swap not supported)
HP Optical Bay HDD Mounting Bracket (used to install greater than four 8.89 cm (3.5 in) HDDs)
HP 2.5in HDD/SSD 2-in-1 Optical Bay Bracket (used to install greater than four 6.35 cm (2.5 in) HDDs)
HP Power cord kit
HP Workstation mouse pad
Feature
Communications
HP i350-T2 PCIe Dual Port Gigabit NIC
Intel i350-T4 PCIe 4-Port Gigabit NIC
Intel Ethernet I210-T1 PCIe x1 Gb NIC
Intel X550-T2 10GbE Dual Port NIC
Intel X710-DA2 10GbE SFP+ Dual Port NIC
HP 10GbE SFP+ SR 1st Transceiver
Power supply
1125 W/100 V/15 A
90% Efficient wide-ranging, active Power Factor Correction (PFC)
Includes four 6+2-pin graphics power cables
1450 W/100 V/15 A
1700 W/100 V/15 A
Button
(1) Front power button and LED
(1) Rear power button
Dimensions (H x W x D)
Footprint
44.45 x 21.59 x 55.12 cm (17.5 x 8.5 x 21.7 in)
Maximum
44.45 x 21.59 x 55.50 cm (17.5 x 8.5 x 21.85 in)
note: |
Rack dimensions
5U
Minimum
22.4 kg (49.38 lb)
Typical
23.7 kg (52.25 lb)
Maximum
31.7 kg (69.89 lb)
note: |
Specification
Preinstalled
Windows 10 Pro 64
HP Installer Kit for Linux
note: Red Hat Enterprise Linux Desktop Workstation
note: |
Supported
Windows 7 Professional 64 (downgrade available by request from HP Support)
note: Red Hat Enterprise Linux Desktop 6 and 7
SUSE Linux Enterprise Desktop 11 SP3 and 12
Sobey video editing software
HP Remote Graphics Software
BIOS
Standard BIOS 32-bit Service Directory Proposal v0.4
PCI Local Bus specification, revision 2.3
PCI Power Management specification, revision 1.1
PCI Firmware specification, revision 3.0, draft .7
PCI Express Base specification, revision 2.0
PCI Express Base specification, revision 3.0
POST Memory Manager specification, version 1.01
ATAPI Removable Media Device BIOS specification version 1.0
WMI support
BIOS Boot spec 1.01+ (disables the ability to boot from removable media on supported devices)
UEFI 2.5
ACPI version 5.0
Enhanced Host Controller Interface for Universal Serial Bus, revision 1.0
LANDesk Management Suite (HP recommended solution)
Microsoft System Center Configuration Manager
HP Client Automation Enterprise
Security
Trusted Computing Group
TPM specification version 2.0
Infineon SLB 9665 (Common Criteria EAL4+
certified)
Remote wakeup/remote
shutdown
Memory change alert
Thermal alert
Security cable with Kensington lock (optional)
HP Chassis Intrusion Sensor (standard)
HP Z640/Z840/Z8G4 Rail Rack Kit
HP Z8 Rack Rail Upgrade Kit
HP Keyed Cable Lock 10 mm
Workstation ISV certifications
Go to the Workstation ISV certifications webpage to see current certifications
note:HP Cloud Recovery download tool (Cloud Recovery Client) is available under Software and Drivers section on the support page.
Feature
Certifications
US ENERGY STAR (select models only)
Low Halogen
note: US Federal Energy Management Program (FEMP)
China Energy Conservation Program
The ECO declaration (TED)
EPEAT Gold registered where applicable (registration varies by country/region)
Temperature
Operating
5° to 35°C (41° to 95°F)
Non-operating
-40° to 60°C (40° to 140°F)
Humidity
Operating
10% to 85% (non-condensing, 35° C maximum wet bulb)
Non-operating
10% to 90% (non-condensing, 35° C maximum wet bulb)
Altitude (unpressurized)
Operating
3,048 m (10000 ft)
Non-operating
9,144 m (30000 ft)
