The following information provides details about the cartridges for the printer, and it includes instructions to replace them.
- ${title}
- ${title}
- ${title}
- ${title}
HP PageWide Color SFP 765, E75160, P75250 - Replace the cartridges
Cartridge information
This printer indicates when the cartridge level is low, very low, or depleted.
The printer uses four colors and has a different cartridge for each color: yellow (Y), cyan (C), magenta (M), and black (K).
Do not remove the cartridge from its package until you are ready to use it.
caution:To prevent damage to the cartridge do not touch the gold-colored metal contacts of the cartridge.
The following illustration shows the cartridge components.
Metal contact. Do not touch the gold-colored metal contacts of the cartridge. Fingerprints on the contacts can damage the cartridge.
Figure : Cartridge components
To purchase cartridges or check cartridge compatibility for the printer, go to HP SureSupply at www.hp.com/go/suresupply. Scroll to the bottom of the page and verify that the country/region is correct.
note:High-yield cartridges contain more pigment than standard cartridges for increased page yield. For more information, go to www.hp.com/go/learnaboutsupplies.
note:Information about recycling used cartridges is in the cartridge box.
Remove and replace the cartridges
Open the cartridge door.Figure : Open the cartridge door
Push the old cartridge inward to unlock it.Figure : Push the cartridge inward
Grasp the edge of the old cartridge, and then pull the cartridge straight out to remove it.Figure : Remove the cartridge
Remove the new cartridge from the packaging.Figure : New cartridge
Do not touch the gold-colored metal contacts of the cartridge. Fingerprints on the contacts can damage the cartridge.Figure : Avoid touching the contact
Insert the new cartridge into the printer. Make sure that the cartridge clicks firmly in place.Figure : Install the cartridge
Close the cartridge door.Figure : Close the cartridge door
Pack the used cartridge in the box that the new cartridge came in. See the enclosed recycling guide for information about recycling.HP helps you recycle your Original HP cartridges—it’s easy and free with the HP Planet Partners program, available in more than 50 countries/regions around the world1).To find information about how to recycle used HP cartridges, please go to www.hp.com/recycle.
1) Program availability varies. For more information, visit www.hp.com/recycle.
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Bulgaria
- ${title}
hp-hero-support-search
- ${title}
