Samsung ProXpress MFP SL-M4560, SL-M4562, SL-C4060, SL-C4062 - Scanning with Samsung Easy Document Creator
Samsung Easy Document Creator is an application to help users scan, compile, and save documents in multiple formats, including .epub format.
  • Available for Windows OS and Mac OS users only.
  • Windows XP Service Pack 3 or higher and Internet Explorer 6.0, or higher, is the minimum requirement for Samsung Easy Document Creator.
  • Samsung Easy Document Creator is installed automatically when you install the printer software (see "Samsung Easy Document Creator" in your printer's User Guide).
  1. Place a single document face down on the document glass, or load the documents face up into the document feeder, see Loading originals.
  2. Select one of the two methods:
    • Windows: From the Start menu select Programs or All Programs>Samsung Printers.
    • Mac: Open the Applications folder>Samsung folder>Samsung Easy Document Creator.
  3. Click Samsung Easy Document Creator.
  4. Click Scan from the home screen.
  5. Select the type of scanning or favorites, and then make adjustments to the image.
  6. Click Scan to scan a final image or Prescan to get another preview image.
  7. Press Send to save the scanned image.
  8. Select the option you want.
  9. Press OK.
Click the Help button from the window, and then click on any option for further information.
