Samsung Xpress MFP SL-M2885 - Printer Specifications
General specifications
These specifications are subject to change without notice. To see additional specifications and information about changes to the specifications, please visit HP Support.
Items
Dimensionsa
Width x Depth x Height
401 x 362 x 367 mm (15.8 x 14.2 x 14.4 inches)
Weighta
Printer with consumables
M2670 series: 10.8kg (23.8 lbs.)
M2870, M2880 series: 11.2kg (24.7 lbs.)
M2671, M2675, M2676 series: 11.1kg (24.5 lbs.)
M2875, M2876, M2885, M2886 series: 11.3kg (24.9 lbs.)
Noise levelb, c
Ready mode
26 dB (A)
Print mode
Less than 50 dB (A)
Scan/Copy mode (scanner glass)
52 dB (A)
Scan/Copy mode (document feeder)
53 dB (A)
Temperature
Operation
10 to 30°C (50 to 86°F)
Storage (packed)
-20 to 40°C (-4 to 104°F)
Humidity
Operation
20 to 80% RH
Storage (packed)
10 to 90% RH
Power ratingd
110 volt models
AC 110 - 127 V
220 volt models
AC 220 - 240 V
Power consumptione
Average operating mode
Less than 400 W
Ready mode
Less than 50 W
Power save mode
M287xFW, M287xDW, M288xFW, M288xHW: Less than 2.4 W (Wi-Fi Direct off: less than 1.6 W)
M267xN, M267xF, M267xFH, M267xFN, M267xHN, M287xND, M287xFD, M287xHN series: Less than 1.1 W
Power off modef
Less than 0.2 W (0.1 Wg)
Network Standby Mode (All Port Activation)
M267xF, M267xFD: Less than 1W
M267xFN: Less than 1.4W
M287xFD, M287xND: Less than 1.35 W
M287xDW: Less than 1.59 W
M287xFW, M288xFW: Less than 1.95 W
Wirelessh
Module
SPW-B4319S
a. Dimensions and weight are measured without a handset.
b. Sound Pressure Level, ISO 7779. Configuration tested: basic printer installation, A4 paper, simplex printing.
c. China only: If the equipment's noise is louder than 63 dB (A), place the equipment in an area of relatively independent advice.
d. See the rating label on the printer for the correct voltage (V), frequency (hertz) and of current (A) for the printer.
e. The power consumption might be affected by the printer’s status, setting conditions, operating environment, and measuring equipment and method the country/region uses.
f. Power consumption can be completely avoided only when the power cable is not connected.
g. For the printer that has a power switch.
h. M287xDW, M287xFW, M288xFW, M288xHW models only, see Features by model.
Print paper specifications
Type
Size
Dimensions
Print paper weight/Capacity (Simplex)a
Tray
Manual feederb
Plain paper
Letter
216 x 279 mm (8.5 x 11 inches)
60 to 163 g/m2 (16 to 43 lb. bond)
250 sheets of 80g/m2 (20 lb. bond) for each tray
60 to 220 g/m2 (16 to 59 lb. bond)
1 sheets of 80 g/m2 (20 lb. bond)
Legal
216 x 356 mm (8.5 x 14 inches)
US Folio
216 x 330 mm (8.5 x 13 inches)
A4
210 x 297 mm (8.27 x 11.7 inches)
Oficio
216 x 343 mm (8.5 x 13.5 inches)
JIS B5
182 x 257 mm (7.16 x 10.11 inches)
ISO B5
176 x 250 mm (6.93 x 9.84 inches)
Executive
184 x 267 mm (7.25 x 10.5 inches)
A5
148 x 210 mm (5.85 x 8.27 inches)
A6
105 x 148 mm (4.13 x 5.82 inches)
Envelope
Envelope Monarch
98 x 191 mm (3.87 x 7.5 inches)
Not available in the tray
Envelope No. 10
105 x 241 mm (4.12 x 9.5 inches)
Envelope DL
110 x 220 mm (4.33 x 8.66 inches)
Envelope C5
162 x 229 mm (6.37 x 9.01 inches)
Envelope C6
114 x 162 mm (4.48 x 6.38 inches)
Thick paper
Refer to the Plain paper section
91 to 105 g/m2 (24 to 28 lb. bond)
Thicker paper
164 to 220 g/m2 (44 to 59 lb. bond)
Thin paper
60 to 70 g/m2 (16 to 19 lb. bond)
Transparency
Letter, A4
138 to 146 g/m2 (37 to 39 lb. bond)
Labelsc
Letter, Legal, US Folio, A4, JIS B5, ISO B5, Executive, A5
120 to 150 g/m2 (32 to 40 lb. bond)
Cardstock
Letter, Legal, US Folio, A4, JIS B5, ISO B5, Executive, A5, Postcard 4x6
121 to 163 g/m2 (32 to 43 lb. bond)
Bond paper
106 to 120 g/m2 (28 to 32 lb. bond)
Minimum size (custom)
Manual feeder: 76 x 127 mm (3 x 5 inches)
60 to 163 g/m2 (16 to 43 lb. bond)d, e
Tray: 105 x 148.5 mm (4.13 x 5.85 inches)
Maximum size (custom)
a. Maximum capacity might differ depending on paper weight, thickness, and environmental conditions.
b. One sheet for manual feeder.
c. The smoothness of the labels used in this printer is 100 to 250 (Sheffield). This means the numeric level of smoothness.
d. The paper types available in the manual feeder: Plan, Thick, Thicker, Thin, Cotton, Colored, Pre-printed, Recycled, Envelope, Transparency, Labels, Cardstock, Bond, Archive.
e. The paper types available in tray: Plan, Thick, Thin, Recycled, Cardstock, Bond, Archive.
System requirements
Microsoft® Windows®
Requirement (Recommended)
CPU
RAM
Free HDD space
Windows® XP Service Pack 3
Intel® Pentium® III 1 GHz (Pentium IV 2 GHz)
512 MB (1 GB)
1.5 GB
Windows Server® 2003
512 MB (1 GB)
1.5 GB
Windows Server® 2008
Intel® Pentium® IV 1 GHz (Pentium IV 2 GHz)
512 MB (2 GB)
10 GB
Windows Vista®
Intel® Pentium® IV 3 GHz
512 MB (1 GB)
15 GB
Windows® 7
Intel® Pentium® IV 1 GHz 32-bit or 64-bit processor or higher
1 GB (2 GB)
16 GB
Support for DirectX® 9 graphics with 128 MB memory (to enable the Aero theme).
DVD-R/W Drive
Windows Server® 2008 R2
Intel® Pentium® IV 1.4 GHz (x64) processors (2 GHz or faster)
512 MB (2 GB)
10 GB
Windows® 8
Windows® 8.1
Windows® 10
Windows® Server 2016
2 GB (2 GB)
20 GB
DVD-R/W Drive
Windows Server® 2012
Windows Server® 2012 R2
512 MB (2 GB)
32 GB
  • Internet Explorer 6.0 or higher is the minimum requirement for all Windows operating systems.
  • Users who have administrator rights can install the software.
  • Windows Terminal Services is compatible with the printer.
Mac
CPU
RAM
Free HDD space
Mac OS X 10.5
Intel® processors
512 MB (1 GB)
1 GB
867 MHz or faster Power PC G4/G5
Mac OS X 10.6
Intel® processors
1 GB (2 GB)
1 GB
Mac OS X 10.7-10.10
Intel® processors
2 GB
4 GB
Linux
Items
Requirements
Red Hat Enterprise Linux 5, 6
Fedora 13, 14, 15, 16, 17, 18, 19
OpenSUSE 11.3, 11.4, 12.1, 12.2, 12.3
Ubuntu 10.04, 10.10, 11.04, 11.10, 12.04, 12.10, 13.04
SUSE Linux Enterprise Desktop 10, 11
Debian 5.0, 6.0, 7.0, 7.1
Mint 13, 14, 15
CPU
Pentium IV 2.4 GHz (Intel Core™ 2)
RAM
512 MB (1 GB)
Free HDD space
1 GB (2 GB)
Unix
Items
Requirements
Sun Solaris 9, 10, 11 (x86, SPARC)
HP-UX 11.0, 11i v1, 11i v2, 11i v3 (PA-RISC, Itanium)
IBM AIX 5.1, 5.2, 5.3, 5.4, 6.1, 7.1 (PowerPC)
Free HDD space
Up to 100 MB
Network environment
Network and wireless models only, see Features by model.
Users need to set up the network protocols on the printer to use it as the network printer. The following table shows the network environments supported by the printer.
Items
Ethernet 10/100/100 Base-TX Wired Lan
Network operating system
Windows® XP, Windows Server® 2003, Windows Vista®, Windows® 7, Windows® 8, Windows Server® 2008 R2
Various Linux OS
Mac OS X 10.5 - 10.10
UNIX OS
Network protocols
TCP/IPv4
DHCP, BOOTP
DNS, WINS, Bonjour, SLP, UPnP
Standard TCP/IP Printing (RAW), LPR, IPP, WSD, AirPrint, Google Cloud Print
SNMPv 1/2/3, HTTP, IPSec
TCP/IPv6 (DHCP, DNS, RAW, LPR, SNMPv 1/2/3, HTTP, IPSec)
