Samsung ProXpress SL-M3820, SL-M4020 - Replacing the Imaging Unit
This document explains how to replace the imaging unit. When the imaging unit has reached the end of its life, the Printing Status window appears on the computer, indicating the imaging unit needs to be replaced.
  • Do not use sharp objects such as a knife or scissors to open the imaging unit package. They might scratch the surface of the imaging unit.
  • Do not touch the green area of the imaging unit. Use the handle on the imaging unit to avoid touching this area.
  • To prevent damage, do not expose the imaging unit to light for more than a few minutes. Cover it with a piece of paper to protect it if necessary.
  • If toner gets on clothing, wipe it off with a dry cloth, and then wash clothing in cold water. How water sets toner into the fabric.
Replacing the imaging unit
Use these steps to replace the imaging unit.
  1. Open the front cover, and then remove the toner cartridge.
      Figure : Opening the front cover, and then removing toner cartridge
    1. Open front cover
    2. Toner cartridge
  2. Pull the imaging unit straight out using the groove.
    Figure : Pulling the imaging unit straight out
  3. Remove the new imaging unit from the packaging. Make sure to recycle the appropriate packaging.
    Figure : Removing the new imaging unit from packaging
    Be careful opening the packaging of the imaging unit. Any scratches or excessive light exposure causes damage to the imaging unit.
  4. Before inserting the new imaging unit, make sure to remove the protective plastic tab.
    Figure : Removing the protective plastic tab
  5. Push the new imaging unit into the printer using the groove.
    Figure : Pushing the new imaging unit into the printer
  6. Slide the toner cartridge back into the printer, and then close the front cover.
    Figure : Reinserting the toner cartridge, and then close the front cover
    1. Insert toner cartridge
    2. Close front cover
